2.5 L Polo 911 Based Engine Dyno
Recently finished dyno run on a 4 cyl 911 based Polo engine.
Cyl heads are 964 w/993 valves prepared by Xtreme cyl head. Bore:102mm. Stroke 76.4mm .92 hp/Liter Jeff [image]http://forums.pelicanparts.com/uploads26/image1661466944.jpg[/img] ![]() ‘
WOW. From one POLO guy to another. Those are awesome numbers.
1959 Auratium Green 356A Super w/ Rudge wheels 1970 Irish Green 914-6 w/2.2S Current -1967 Bahama Yellow 912 POLO 2cam4 #1 Handles like a 912 and goes like a 911 www.reSeeWorks.com |
DC43/112 Cams ground by John Dougherty
are installed Last edited by Jabate; 08-25-2022 at 05:22 PM.. |
"Recently finished dyno run on a 4 cyl 911 based Polo engine.
Cyl heads are 964 w/993 valves prepared by Xtreme cyl head. Bore:102mm. Stroke 76.4mm .92 hp/Liter" Polo engine, as in vw polo? 4cyl with964 heads? I feel dizzy, do you have any pictures? Thanks, Phil |
It's a 914 ...
Polo is a 4 cyl engine roughly based on the 911, and uses 911 parts including the heads. Pretty cool motors.
Polo 2.5L Engine
May I ask what exhaust system you have installed.
Thank you Ralph |
Rarely L8 tuned 1 5/8” stainless headers and Rarely L8 stainless dual in/out muffler
Built by Rarely L8 Motorsports/M&K Muffler |
That engine is a beauty Jeff.
Jeff, if you don't mind I have another question, what size valve did Bill install on your heads.
Thank you Ralph |
50 mm intake w/8mm stems; 42.5mm ex. W/8mm stems
The confusion is understandable. The motors are from Dean Polopulos hence “Polo.” Do yourself a favor and Google “Porsche Polo” and check out the videos…and turn up the volume. The sound is pure nirvana.
Ass-engine Nazi slot car -- PJ O'Rourke |
Wow, looked it up, it's a pretty involved beast, could probably spend weeks reading and still only scratch the surface. Very cool indeed.
Phil |
Go to www.polomotor.com
The Bahama Yellow 912 is mine. It makes maybe 190 hp. It's quick. Jeff's 912 will be a rocket.
Message I get, hopefully they paid their bills.
Account Suspended This Account has been suspended. Contact your hosting provider for more information. |
Some pictures of the case, w/cyls/heads minus chain boxes.
Pictures of split case showing 5 bearing crank Pictures of headers before heater boxes added ![]() ![]()
I talked to Dean. The site should be back up in a week or so.
Delivered for instillation
