PMO Venturi compatibility question
Can I use Weber venturies in PMO carbs, are they the same?
Thanks |
Edit: to add to that answer, the PMO bodies were designed to accommodate 50 bores. Because of the design, the diameter of the Weber venturis are too small. |
Got it, thanks Henry!
| All times are GMT -8. The time now is 12:58 AM. |
