Phrog's Avatar
PMO Venturi compatibility question
Can I use Weber venturies in PMO carbs, are they the same?
Kevin
84 911 Carrera
71 911E Vintage Race Car
25 Ford Explorer ST
20 Subaru Crosstrek
Old 08-28-2022, 07:49 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Originally Posted by phrog View Post
can i use weber venturies in pmo carbs, are they the same?
no
Edit: to add to that answer, the PMO bodies were designed to accommodate 50 bores. Because of the design, the diameter of the Weber venturis are too small.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-02-2022, 05:10 PM
Phrog's Avatar
Got it, thanks Henry!
Kevin
84 911 Carrera
25 Ford Explorer ST
20 Subaru Crosstrek
Old 09-10-2022, 05:40 PM
