JB weld
Can you JB weld the outside of engine 911s 1975? I cracked a small chunk of the engine at the base of the oil temperature sensor while dropping the engine out from my car.
I think that is your only option. Clean the are really well and apply the JP Weld. Is it just a chip or a crack that transverses into the threaded section?
Can you share a pic? JB Weld is marvelous stuff, but it does have limits. If it's a lower stress area, it may be fine.
Try a high metal content type.
Our go to epoxy for case work is Loctite Hysol. 9340 We supply it in a case sealant kit available from our host. https://www.pelicanparts.com/More_Info/SPTCSUPCSK001.htm?pn=SPTC-SUP-CSK-001&q=supertec http://forums.pelicanparts.com/uploa...1662240544.png |
Welding with the appropriate machine work is the best way to fix it but a TimeSert would do just fine.
So jBweld won't be the best fix. Timesert would be the best way to fix this. Henry, Thanks
I cannot proceed my project until this broken piece resolved. Thanks
A different case is the best move. Anything else is a crap shoot. Not much depth in that hole for a timesert to grab and the fitting needs to be pretty tight to seal. Too much undeserved love for JB weld in situations like this. I had one welded once and the weld popped off upon tightening the fitting.
| All times are GMT -8. The time now is 02:04 AM. |
