JB weld
Can you JB weld the outside of engine 911s 1975? I cracked a small chunk of the engine at the base of the oil temperature sensor while dropping the engine out from my car.
Old 09-01-2022, 10:26 PM
I think that is your only option. Clean the are really well and apply the JP Weld. Is it just a chip or a crack that transverses into the threaded section?
Old 09-01-2022, 11:20 PM
It's a 914 ...
stownsen914's Avatar
Can you share a pic? JB Weld is marvelous stuff, but it does have limits. If it's a lower stress area, it may be fine.
Old 09-02-2022, 05:24 AM
https://www.belzona.com/en/products/1000/1111.aspx
Old 09-02-2022, 01:52 PM
Try not, Do or Do not
Henry Schmidt's Avatar
An insert might be a better option.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-02-2022, 04:11 PM
Try a high metal content type.
Old 09-02-2022, 08:58 PM
Yes. It is a crack that transverse into threaded section.
Old 09-03-2022, 02:03 PM
I will post the picture of the area tomorrow
Old 09-03-2022, 02:04 PM
About 10% of the threaded area came of in a chunk
Old 09-03-2022, 02:10 PM
Without a picture, it's hard to make an accurate assessment but still, install an insert [Timesert is probably best] and replace the missing piece with an epoxy.
Our go to epoxy for case work is Loctite Hysol. 9340
We supply it in a case sealant kit available from our host.
https://www.pelicanparts.com/More_Info/SPTCSUPCSK001.htm?pn=SPTC-SUP-CSK-001&q=supertec
Henry Schmidt
Ph: 760-728-3062
Old 09-03-2022, 02:31 PM
Here are the pics of the damaged area.
Old 09-04-2022, 02:12 PM
Here is another pic
Old 09-04-2022, 02:15 PM
Welding with the appropriate machine work is the best way to fix it but a TimeSert would do just fine.
Henry Schmidt
Ph: 760-728-3062
Old 09-04-2022, 04:21 PM
So jBweld won't be the best fix. Timesert would be the best way to fix this. Henry, Thanks
Old 09-04-2022, 07:55 PM
I believe a combination of a TimeSert reinforced by an epoxy. Insert the sleeve until flush with the original mounting surface and then fill in the missing piece with epoxy. With a little patient sanding, you can probably make it look pretty good.
Henry Schmidt
Ph: 760-728-3062
Old 09-05-2022, 09:55 AM
I cannot proceed my project until this broken piece resolved. Thanks
Old 09-06-2022, 02:12 PM
A different case is the best move. Anything else is a crap shoot. Not much depth in that hole for a timesert to grab and the fitting needs to be pretty tight to seal. Too much undeserved love for JB weld in situations like this. I had one welded once and the weld popped off upon tightening the fitting.
206 637 4071
Old 09-06-2022, 04:29 PM
