Simple Cam Question modified 3.0
My question is this:
To change to a "suitable" cam profile to make use of a high compression 3.0SC engine with EFI/ITB, is it better to A) regrind a 4 bearing 3.0 SC camshaft set B) buy a "suitable" 4 bearing camshaft set (i presume you can easily purchase modified 4 bearing camshafts?) C) Switch to a 3 bearing camshaft and cam housing, such as an "early 911S" camshaft. ---- In all honestly I am 2-3 years from building a 3.0 engine which would run single plug, high compression (less than 10:1), and EFI/ITB. In fact I have not yet fully decided the spec, as I am still learning the best route. In the meantime, I have seen some "early 911S cams" in good condition, along with some 3 bearing cam housings, and I am wondering whether to buy them, or if sticking with the 4 bearing cams/housings is the only way to go.... Last edited by strictly; 08-31-2022 at 01:39 PM.. |
stay with your 4 bearing camshaft.
You can get quality cams either reground, or from new billet, from John Dougherty or Webcamshafts etc...
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Steve's comments may interest you: twin plug or not Last edited by Peter M; 08-31-2022 at 02:57 PM.. |
Ok brilliant, thanks for the advice. I will pass on the 3 bearing S cams/cam carriers, and stick with the 4 bearing stuff. I will also re-visit the idea of single plug in favour of a twin plug for high compression/EFI/ITB.
At the moment I am still figuring out the best route, the idea is to decide on that, then start buying parts. That way when I get to the actual build I have already accumulated alot of what I need. Luke |
Try not, Do or Do not
The 3 journal cams are designed for a longer valve heads so dimension becomes an issue. Sell those factory "S" to finance your new purchase. Cam selection is entirely based on person use parameters. If you want to use your SC cams, regrinding them to 964 profile is pretty common. This is a conservative choice but very driveable. My preference for street performance leans towards the 993 SS cams. Reasonable performance throughout the rpm range for a smaller motor. DC-993SS I/E 248/234 242/228 .490".455" 114 1.6-1.8 mm Maybe go with a closer lobe center [106/8] if you want to go a little more aggressive.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
You might talk to Al Kosmal at X-Factory who builds engines and sells ITB EFI systems. He guided me on my 3L SC rebuild with 9.8:1 euro pistons. After discussing it with Al, we decided the stock SC cams suited what I wanted for the car (73 911T).
But the other comments here are certainly informative. |
I can chat to them, but also nice to observe and record other specs. In fact any ideas on upgrading a 1979 180HP 3.0SC ROW euro engine and I am all ears! I am only looking for fun street use, and to gain a bit of MPG over the CIS design SSI's of course, its more the P&C/ITB/EFI/and Cams/Cylinder Heads (valve sizes, etc) im not too sure on. |
