Broken Crank Trigger
Hello all! Sooo I might have broken off the trigger while trying to remove it from my flywheel. I have looked for a replacement part, but I have not been able to find one. Does anyone know where I can get one? Thanks in advance!
![]() Sent from my iPad using Tapatalk
1984 Hellbronze Metallic M491 |
Steel allen head bolt. Steel, not stainless.
Awesome, that’s easy! Thanks! Do you happen to know the air gap that is needed between the trigger and sensor? Sent from my iPhone using Tapatalk
'77 S with '78 930 power and a few other things. |
Checking the flywheel in the PET, I think you are looking for 930-102-221-00, threaded pin.
Perfect thanks! Sent from my iPhone using Tapatalk
