Undersize Main Bearing Source
I had to have my 66mm Crank ground .25 under. I need to obtain main bearings. I have heard that the Glyco bearings have had some issues in the past and should be avoided.
I have been advised to use clevite coated bearings. Does anybody have any suggestions on where to source and obtain these bearing, or any other relevant advice to purchasing undersize main bearings for my motor? Direct links are always appreciated. Thank you in advance! |
I got mine from Henry at Supertec last year.
Sent from my SM-G991U using Tapatalk |
Try EBS Racing.
Porsche Dealer
it's not leaking....it's just marking it's territory |
Thank you all for the information.
