I'm in the middle of the rebuild and just got my pistons and cylinders back and wouldn't you know it I can not find anything on the direction the pistons need to go in. I have a 50/50 chance of getting right however... So these are Mahle 90L58 pistons (see photos). They were probably a mid year change by Porsche but I have not seen any others around on any videos only on here have I see n mention. So i really hope I get a quick return on this message. Everything being equal and the excellent engineering of this engine it would stand to reason that the writing on the cylinder would be in the same direction as the writing on the piston. Anyhow please assistance is required. Thanks.
2.7 CIS pistons?
Usually on the drivers side of the engine the bump on the piston goes towards flywheel Passenger side of the engine bump goes towards the crank pulley If you put them in wrong pretty sure you’ll find out pretty quickl after you install your rocker arms because the there will be some “piston stops”
it's not leaking....it's just marking it's territory |
My train is the concave side is toward the spark plug
Bruce |
Just remember, lump to the left. Nothing to do with the flywheel on CIS pistons. The top of that cylinder looks bad, btw.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 10-10-2022 at 08:45 AM.. |
So basically the way I have them placed in the photo is correct. I had assumed that this is correct but better to check with others.
This side Up.
![]() Down
Ed 1973.5 T |
I wouldn't use it.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 10-11-2022 at 05:58 AM.. |
Usually when you find junk, you trash it. I don't see why anybody would use that.
How do you determine "junk" from a photo? Wouldnt depth of pitting, degredation of the seating area only be known by having it on hand?
We can see the pitting/fretting/degradation of the fire ring (worst on the right side of the barrel). Where the "head gasket" goes. I'm in the same camp as John; no, I would not run it like that.
You should be able to locate one cylinder to replace it. John might actually have one. If not, Henry likely does. Or post a WTB ad in the classifieds. |
"I had my local Porsche guy refinish the cylinders they said it looks bad but should still be ok. Thanks for the info"
Get a new local Porsche guy. lol Don't use it .
'77 1973 911RS Backdate, 2.7 liter w/webers '70 911ST , 3.2 liter '82 '74 911 IROC Tribute , 3.0 in progress '75 911 RSR street car in progress '77 930 Replica '75 993 GT2 EVO race car , 3.6 TT '79 928 5 speed money pit in progress |
Take a good look.........
Al, Listen to John W. You and I or most of the people in this forum will not have enough experience to even come closer for comparison. Take a good look at the top of the cylinder shown in the picture. It is heavily pitted. I personally will not use or recommend this cylinder for use. It is a bad cylinder and should be discarded and replaced. An experienced and knowledgeable engine rebuilder would never even think of using it. Tony |
Not much chance of that sealing properly for long or more likely, at all. Chuck it and get a replacement. And make sure all the corresponding head surfaces are OK. No sense doing the job twice.
1986 Targa Guards Red 2021 MT09 SP |
Looks like the victim of a broken case stud. Using that would make me lose sleep.
Banned
Speed Test Last edited by harrydarwen; 11-01-2022 at 06:53 AM.. |
| Tags |
| '74 911 pistons , mahle pistons |
