Porsche Crest Mahle Pistons and correct installation
I'm in the middle of the rebuild and just got my pistons and cylinders back and wouldn't you know it I can not find anything on the direction the pistons need to go in. I have a 50/50 chance of getting right however... So these are Mahle 90L58 pistons (see photos). They were probably a mid year change by Porsche but I have not seen any others around on any videos only on here have I see n mention. So i really hope I get a quick return on this message. Everything being equal and the excellent engineering of this engine it would stand to reason that the writing on the cylinder would be in the same direction as the writing on the piston. Anyhow please assistance is required. Thanks.
Old 10-09-2022, 06:20 PM
2.7 CIS pistons?
Usually on the drivers side of the engine the bump on the piston goes towards flywheel
Passenger side of the engine bump goes towards the crank pulley
If you put them in wrong pretty sure you’ll find out pretty quickl after you install your rocker arms because the there will be some “piston stops”
it's not leaking....it's just marking it's territory
Old 10-09-2022, 08:13 PM
My train is the concave side is toward the spark plug
Bruce
Old 10-10-2022, 04:50 AM
Just remember, lump to the left. Nothing to do with the flywheel on CIS pistons. The top of that cylinder looks bad, btw.
206 637 4071
Old 10-10-2022, 08:43 AM
I had my local Porsche guy refinish the cylinders they said it looks bad but should still be ok. Thanks for the info
Old 10-10-2022, 11:27 AM
Originally Posted by Zuffenwerker View Post
2.7 CIS pistons?
Yup they are CIS. Thanks.
Old 10-10-2022, 11:32 AM
So basically the way I have them placed in the photo is correct. I had assumed that this is correct but better to check with others.
Old 10-10-2022, 11:35 AM
E Sully's Avatar
This side Up.
Down
Ed
1973.5 T
Old 10-10-2022, 04:47 PM
I wouldn't use it.
206 637 4071
Old 10-11-2022, 05:56 AM
Is your opinion based on building an engine for a customer, that you have to warranty? Someone tackling their own rebuild / reseal may have to make some choices for economic reasons.
I wouldn't use it.
Old 10-11-2022, 06:51 AM
Usually when you find junk, you trash it. I don't see why anybody would use that.
206 637 4071
Old 10-11-2022, 10:43 AM
How do you determine "junk" from a photo? Wouldnt depth of pitting, degredation of the seating area only be known by having it on hand?
Old 10-12-2022, 06:45 AM
We can see the pitting/fretting/degradation of the fire ring (worst on the right side of the barrel). Where the "head gasket" goes. I'm in the same camp as John; no, I would not run it like that.
You should be able to locate one cylinder to replace it. John might actually have one. If not, Henry likely does. Or post a WTB ad in the classifieds.
Old 10-12-2022, 10:08 AM
"I had my local Porsche guy refinish the cylinders they said it looks bad but should still be ok. Thanks for the info"
Get a new local Porsche guy. lol Don't use it .
'77 1973 911RS Backdate, 2.7 liter w/webers
'70 911ST , 3.2 liter '82 '74 911 IROC Tribute , 3.0 in progress
'75 911 RSR street car in progress
'77 930 Replica '75 993 GT2 EVO race car , 3.6 TT
'79 928 5 speed money pit in progress
Old 10-12-2022, 12:28 PM
Take a good look.........
Al,
Listen to John W. You and I or most of the people in this forum will not have enough experience to even come closer for comparison. Take a good look at the top of the cylinder shown in the picture. It is heavily pitted. I personally will not use or recommend this cylinder for use. It is a bad cylinder and should be discarded and replaced. An experienced and knowledgeable engine rebuilder would never even think of using it.
Tony
Old 10-12-2022, 12:46 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Not much chance of that sealing properly for long or more likely, at all. Chuck it and get a replacement. And make sure all the corresponding head surfaces are OK. No sense doing the job twice.
1986 Targa Guards Red
2021 MT09 SP
Old 10-12-2022, 03:02 PM
Senior Member
Looks like the victim of a broken case stud. Using that would make me lose sleep.
Old 10-20-2022, 06:09 AM
Banned
Speed Test
Old 11-01-2022, 01:12 AM
Tags
'74 911 pistons , mahle pistons
