Flare type on MFI hard fuel lines?
Hi,
in the process building a MFI-pump test setup I was wondering what the type of flare on the (hard) fuel lines between injector and pump are?
Are they of a special type/name and what are the tools to make them if it is not the standard type of brake line flare set?l
They do not look like any of the brake line flare/flanges I am familiar with.
Thanks,
Bart
Old 11-11-2022, 03:19 AM
Ingenieur
Can you post a pics to be sure what we are talking about. There is a DIN standard (now ISO standard) that covered those. There are some diesel flaring tools that might work, but they are uncommon now.
Old 11-11-2022, 07:45 AM
Ingenieur
Look up ISO bubble flare and see if it looks like that.
Old 11-11-2022, 07:48 AM
Porsche fuel line fittings are called jic fittings with a 37 degree flare. Used for fuel and hydraulics.
Old 11-11-2022, 08:01 AM
356RS's Avatar
Cohline M12 cone nipple with a M12 x 1.5 swivel nut on high pressure (400 psi) poly fuel line is easy to find and use compared to locating and making up steel hardline for a test stand.
Mark Jung
Bend, OR
MFI Werks.com
Old 11-11-2022, 08:15 AM
(man/dude)
Jonny042's Avatar
Mark is right - when I was looking to build my rig I ended up ordering cohline fittings and polyamide line from Europe (finjector.com). So they should be able to supply to you pretty affordably.
The place I link to below has everything you need and should give you some clues as to where to find it or what to search for - the link is to the swivel joint, with references to the nut and line as well.
https://tinyurl.com/j5u9k834
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 11-15-2022, 04:59 PM
Belmetric also has the fittings and lines I believe.
it's not leaking....it's just marking it's territory
Old 11-15-2022, 05:29 PM
