Fuel pumps for carburettors
Hi guys...
My 1980SC will soon inherit a 2.8 on carbs as the 1st stage of a backdate.
Can anyone recommend an appropriate fuel pump setup for such a conversion?
Currently runs a Bitz racing EFI with standard pump/filter/accumulator setup.
TIA.
Mark
914/6 GT (Repro) Tarmac Rally car
928 S4 - 1989
911SC - 1980
944 TURBO - 1986
944 S2 - 1990
Old 10-27-2022, 01:05 AM
H-viken's Avatar
I use two Red Top pumps in series, one in the smuggler box and one at the back.
Important is that you have pumps that provide a high flow at a low pressure.
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 10-27-2022, 02:26 AM
Thanks H. Is there any point in keeping the accumulator?
928 S4 - 1989
911SC - 1980
944 TURBO - 1986
944 S2 - 1990
Old 10-27-2022, 02:44 AM
PMO recommends a few, one is a Holley, I forget the version, but it's red! It works. Pump goes near tank as low as possible. Run hose from tank to pump inlet, then outlet to and through a PMO pressure regulator near engine. Then from pressure regulator through carbs then return line back to tank.
Old 10-27-2022, 06:57 AM
H-viken's Avatar
I use two Malpassi filters, one per bank, as pressure regulators
Not sure about the accumulator , I don’t have one
911E Coupe -70
Old 10-27-2022, 08:00 AM
I use a Hardi pump installed in the engine bay for my sc. have it setup just like a 60s car it works beautifully. No filter, accumulator, or regulator.
it's not leaking....it's just marking it's territory
Old 10-27-2022, 11:32 AM
Arrow
I replaced the 78 CIS stock fuel pump with a new low volume pump;
It was an adventure finding the right size fuel lines, ended up with 7/16” ID for the 6” piece from the tank to the pump, and 3/8” ID from the pump to the feed.
This is a L shaped bracket I had on hand, just drilled a couple holes and it mounted in the stock location perfectly.
No accumulator, not needed and I think they are problematic with low pressure pumps.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 10-27-2022, 02:04 PM
Low pressure fuel pumps for that magical 3.5psi
I have found that most fuel pumps are not consistent in output pressure without a regulator. One day it is 5psi cold, then dwindles to 2 psi when hot.
Last time a carbed 911 needed a pump, I bought a 7 psi pump and regulator to dial in a consistent 3.5 psi that PMO's and Webers like.
Mr Gasket 9710 regulator worked well for 220 HP. Not sure if it would flow for more power.
Specs are 9psi max inlet pressure, adjustable 1 to 6 psi output.
Track: 91 C2 SuperCup wannabe, 08 Cayman S
Street: 85 RUF BTR Slant-nose, 70 911 T Coupe Pastel Blue
Projects: 82 911 SC 3.6, 72 911 T Coupe, 74 914 Signal Orange
Old 10-29-2022, 10:53 AM
Away for the week and just got back to this.
Thank y'all for the replies - seems to be several viable options.
I am going to try using the existing fuel pump and filter with a Malpassi 30044 Bypass Fuel Pressure Regulator and eliminate the accumulator.
Cheers,
Mark
928 S4 - 1989
911SC - 1980
944 TURBO - 1986
944 S2 - 1990
Old 11-04-2022, 06:41 PM
