Uncertifiable!!!
Uwon's Avatar
Fuel Regulator Damper-‘86 3.2
I’m replacing my damper because it was leaking and the attached vacuum hose sucked up the leaking fuel directly into the throttle body. Engine complained terribly finally giving up the ghost completely. Looking at my OEM damper, I note that there is a bolt at the bottom which holds a bracket and also plugs a threaded hole into the diaphragm cavity. The bolt and washer are precisely machined to seal onto the cavity hole. Is the bolt supposed to have a gasket to seal the cavity from the atmosphere? If not, atmospheric pressure would in time pass through into the cavity. BTW, the PET does not show a gasket.
TIA
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 11-12-2022, 08:39 PM
Uncertifiable!!!
Uwon's Avatar
Anyone?
Old 11-13-2022, 06:16 PM
7.0:1 > 11.3:1 > 7.0:1
It’s a blind hole, nothing needed.
Old 11-14-2022, 12:34 PM
Pressure Test.........
Johan,
It is nothing but a mounting hole as shown above. To make you feel better:
If you could not create a vacuum reading, it is leaking and deemed defective.
Tony
Old 11-15-2022, 06:58 AM
Uncertifiable!!!
Uwon's Avatar
Thanks guys for clarifying. Just got a new damper (apparently last one in all of Canada) so fingers crossed.
Cheers,
Johan
Old 11-15-2022, 07:28 PM
Uncertifiable!!!
Uwon's Avatar
Tony,
Your post was very helpful and got me thinking.
I don’t have a vacuum tool, so I Jerry-rigged a pressure test gismo from an old fuel line, stuck a vacuum line on to the damper with the other end in water, applied 50 psi air pressure and Voila!…
Bubbles immediately appeared from the tube end in the water.
Cheers,
Johan
Old 11-16-2022, 07:44 PM
Troubleshooting..........
Johan,
The test for the fuel damper is very similar to testing a fuel accumulator. Applying pressure to the damper will confirm the integrity of the diaphragm. Using low air pressure is sufficient for the test. Good job.
Tony
Old 11-18-2022, 07:09 AM
