-   -   It’s amazing things you find on someone’s build (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1129460-s-amazing-things-you-find-someone-s-build.html)
Flat6pac 11-09-2022 02:56 PM
I hadn’t seen this before…
http://forums.pelicanparts.com/uploa...1668037649.jpg
targa72e 11-09-2022 08:58 PM
The oi pressure sender in the lower oil gallery required some work. You have to remove the plug and tap with appropriate threads (or in this case maybe close). plenty of solutions with pressure light and sensor in one to avoid doing this.
john
winders 11-09-2022 11:35 PM
You mean like in this photo??
http://forums.pelicanparts.com/uploa...1300923901.jpg
Not an uncommon location....and better than the breather cover.
Neil Harvey 11-10-2022 04:51 AM
Originally Posted by Jeff Alton (Post 11842852)
Bruce,
you don't say.... lol
Took this 2.7 apart on last Friday.... oh my.
http://forums.pelicanparts.com/uploa...1667966307.jpg
http://forums.pelicanparts.com/uploa...1667966353.jpg
http://forums.pelicanparts.com/uploa...1667966371.jpg
But this is not the worst we have seen... 3.2 cylinders installed upside down. Missing fasteners, missing oil pump seals where the "new" engine made ZERO oil pressure. It was a 964 3.6, they removed the oil pressure warning bulb before delivering the car. It made it about 12 miles before it came to us on a flatdeck... And the list goes on.....
In a perfect engine, no sealant would ever be required. Unfortunately, no engine is ever perfect and we never are prepared to take the risk.
Give someone a tube to squeeze, how do you tell them, don't squeeze too much???
Flat6pac 11-10-2022 05:19 AM
Just think of the cleanup, it’ll peel right off…except in the oil galleys, rocker oilers, the piston squirters, on and on.
Bruce
targa72e 11-10-2022 10:42 AM
No, Some early cars did not have a oil pressure sender like the one circled in red. They only had the switch for the light.
http://forums.pelicanparts.com/uploa...1668109172.jpg
You can get early and late (993) senders that have a oil pressure switch for the light and a sender for the gauge all in one. That would have been easier than tapping front for sender.
http://forums.pelicanparts.com/uploa...1668109259.jpg
john
stanglife 11-10-2022 11:21 AM
I have a supposed 4.0l built by MotorMeister that will be disassembled early next year. I'll bring you guys on the road to discovery as it comes apart :) I'm an air-cooled newb but I know there are certain ways to do things and I've learned a lot from this bunch - so I'm pretty sure I can spot some craziness in there.
Jeff Alton 11-10-2022 10:25 PM
Here is the one I mentioned earlier "rebuilt by pro shop" with cylinders on upside down and 2 piece return tubes.... Motor had about 1000 miles on the "rebuild"....
http://forums.pelicanparts.com/uploa...1668151430.jpg
Cheers
spuggy 11-13-2022 09:13 AM
Also VDO/Continental parts providing the warning switch and a 5 or 10 bar pressure sender available in an assortment of thread sizes.
https://www.vdo-instruments.com/sensors/pressure-senders-switches/pressure-sensor-with-warning-contact.html
For example, 360-023 is a combo switch/10 bar sensor in M10x1.0 that O'Reilly list for less than $40. Mine says "Made In Germany" on the packaging.
Ovis 11-15-2022 04:55 PM
Cheers
Just for a neophyte's knowledge, are the two piece collapsible tubes to be avoided? What do you guys recommend when doing a rebuild, the collapsible oil return tubes or the one piece versions? Aluminum or Steel?
Thanks!
Jeff Alton 11-15-2022 05:00 PM
The two piece are the only solution to replace leaking ones on a motor that is not coming apart, so they do serve a useful purpose. When rebuilding we only use OE one piece steel ones. Others may have differing opinions mind you.
Cheers
Flat6pac 11-16-2022 03:38 AM
I always enjoy solid return tubes for look and function
Got boxes of split ones used, don’t know why….
Bruce
Henry Schmidt 11-16-2022 08:28 AM
We've been running a double sending unit for decades. To clean up the wiring we make a custom harness.
http://forums.pelicanparts.com/uploa...1668617537.jpg
http://forums.pelicanparts.com/uploa...1668617601.jpg
Henry Schmidt 11-16-2022 08:31 AM
Originally Posted by Flat6pac (Post 11843733)
Screwing a late sender directly into the case is new to me. I like that option.
Allows for a late double to be fitted.
Moving the sending from the front of the case to the rear cleans up the cam feed lines as well.
Cloggie 11-16-2022 09:43 PM
Yes, very good idea....can any of you share the part number for the correct double sensor? My engine build is just beginning and I am making a custom engine harness anyway (it is Motec/Rasant for EMS)...so this sounds much cleaner.....
Thanks in advance!
D.
spuggy 11-20-2022 08:01 AM
Thanks in advance!
D.
Post #29 in this thread https://forums.pelicanparts.com/911-engine-rebuilding-forum/1129460-s-amazing-things-you-find-someone-s-build.html#post11846671 has a link to the VDO catalog.
I bought 10 bar sensor because that's what my gauge uses/appropriate for 930 oil pump output. I'm fairly confident input impedance on the Motec wouldn't mess with the gauge reading too much if you were to "tee" the original sensor - but for $40, you can add an extra sensor and leave the gauge entirely alone.
Pretty sure M10x1.0 matches the factory pressure switch fitting from what I've read.
Cloggie 11-20-2022 09:01 AM
Thank you!
D.
onboost 11-21-2022 08:26 AM
Ha! Nice thread Bruce!
More of the messy.. in the process of tearing down 3.2 and find these "unique" RSR rocker seals, aluminum washers on case thru-bolts, and silicone as case sealer everywhere! :eek:
http://forums.pelicanparts.com/uploa...1669051296.jpg
proporsche 11-22-2022 01:04 PM
...here in Czech we have some special guy working on 911..and others..it is lovely-NOT to do jobs after him..red silicone everywhere-the time to clean it takes longer then assembly of the engine;-)
The latest is the best ,crushed oil tube on camshaft housing after he put mismatched cyl and piston on engine he rebuild..price( i know that one) $8K...oh well garage is full .time to go to work..oh ya bent valves
btw, thanx again John W.
the mid pic is 993 ..had to do service, nightmare it was
http://forums.pelicanparts.com/uploa...1669153780.jpg
http://forums.pelicanparts.com/uploa...1669153780.jpghttp://forums.pelicanparts.com/uploa...1669154637.jpg
proporsche 12-13-2022 12:54 AM
well? i just got in 1973 engine from USA ...(do not know where has been) but some genius put in chain tensioners update kit-lovely...since the chain were too stretched he figured out this--never mind all brown rails...camshaft shims and oil shim upside down..http://forums.pelicanparts.com/uploa...1670925004.jpg
