brandett's Avatar
Cylinder flycut
One of my cylinders were damaged due to two broken studs on the same cylinder, not much but I will fix it. The cylinder head shows no damage, but they will be checked by a shop.
As I have read in Waynes book I need to adjust and check the deck height after this and this got me thinking (again...)
Can I just flycut one cylinder 0.25 mm and use an oversize base gasket to compensate this ?? Or is this just a crasy thought that i should keep to myself ( to late... ) It is not about saving money, but i cant get this out of my mind and would like to hear your opinion.
Itīs my hobby.
911 SC -82 coupe.
My Project
Old 06-01-2003, 08:50 AM
Banned
snowman's Avatar
You could probably cut all 3 cylinders to the same height, then use base gaskets on all of them. In theory your idea should work but, I would worry that a single cylinder would not match the rest close enough. I am likely wrong about this but thats what I would do just to be safe.
Old 06-01-2003, 10:03 PM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
What about the recess/relief for the head gasket? Can the head gasket compress another .25mm? Maybe something to look into.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 06-02-2003, 07:32 AM
i've done that on all six, and it worked fine. loose heads will certainly pound the top edge out of true. nix on the "one only" thought. the head o ring will take an extra 1/4 mm (0.25) squish. use 0.50 base gaskets to compensate.
206 637 4071
Old 06-02-2003, 08:09 AM
