-   -   Hint of the day if rebuildin 964/993 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1130123-hint-day-if-rebuildin-964-993-a.html)
Bill Verburg 11-18-2022 01:39 PM
The green Victor Reinnz cylinder base gaskets that come w/ most rebuild gasket sets are not gonna work, they are an ovalized version of the correct round black gaskets,
don't be fooled by the part #s, as both gaskets have the same Porsche Part #
Get the correct ones from Neil Harvey or another knowledgeable supplier
Henry Schmidt 11-18-2022 02:00 PM
The key is to buy Wrightwood Racing gasket sets. Every washer, seal, o-ring and gasket is the best quality available.
superninety 12-01-2022 05:35 PM
+1 on Wrightwood !! Used it on my 3.6 four years ago. Still tight.
I saw a 964 motor have to come completely back apart after a local shop used a Victor Reinz kit. Leaked like a sieve. Mechanic was "not happy".
r lane 06-28-2024 06:18 AM
I should have been more specific. I am looking for a copper shim that would fit a 3.6, as in .010'', .020'', not the 0 ring. Thanks, Bob
JoeMag 06-28-2024 06:27 AM
LN engineering or if you need some odd ball sizes, I’ve gotten them from Jae Lee (though they were bore in size).
Jeff Alton 06-28-2024 06:47 PM
All of these o-rings in question are readily available from most hydraulic seal supply houses. In a variety of materials and durometers. Neil, Charly etc are not having them made custom.... :) But, sure, easier to buy from someone who has already done the research.
Cheers
