Bill Verburg's Avatar
Hint of the day if rebuildin 964/993
The green Victor Reinnz cylinder base gaskets that come w/ most rebuild gasket sets are not gonna work, they are an ovalized version of the correct round black gaskets,
don't be fooled by the part #s, as both gaskets have the same Porsche Part #
Get the correct ones from Neil Harvey or another knowledgeable supplier
Bill Verburg
Old 11-18-2022, 01:39 PM
Try not, Do or Do not
Henry Schmidt's Avatar
The key is to buy Wrightwood Racing gasket sets. Every washer, seal, o-ring and gasket is the best quality available.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-18-2022, 02:00 PM
superninety's Avatar
+1 on Wrightwood !! Used it on my 3.6 four years ago. Still tight.
I saw a 964 motor have to come completely back apart after a local shop used a Victor Reinz kit. Leaked like a sieve. Mechanic was "not happy".
Old 12-01-2022, 05:35 PM
I should have been more specific. I am looking for a copper shim that would fit a 3.6, as in .010'', .020'', not the 0 ring. Thanks, Bob
Old 06-28-2024, 06:18 AM
JoeMag's Avatar
LN engineering or if you need some odd ball sizes, I’ve gotten them from Jae Lee (though they were bore in size).
Old 06-28-2024, 06:27 AM
Jeff Alton's Avatar
All of these o-rings in question are readily available from most hydraulic seal supply houses. In a variety of materials and durometers. Neil, Charly etc are not having them made custom.... But, sure, easier to buy from someone who has already done the research.
Cheers
www.turn3autosport.com
Old 06-28-2024, 06:47 PM
