polo 2.5 Liter 911 based engine Dyno
Just finished the dyno of a 2nd Polo engine. This engine is equipped with Xtreme Cylinder heads; Jenvy tapered 48 mm throttle bodies; DC 44/112 cams; Rarely 8/M&K 1 3/4” equal length headers w/heater boxes;Carrillo rods; Wossner pistons;Nikie cylinders; Glen Yee modifed oil pump; Rasant harness;
Old 11-30-2022, 12:51 PM
It's a 914 ...
stownsen914's Avatar
Nice!
Old 11-30-2022, 03:49 PM
cmpski's Avatar
Way beyond nice!
1959 Auratium Green 356A Super w/ Rudge wheels
1970 Irish Green 914-6 w/2.2S
Current -1967 Bahama Yellow 912 POLO 2cam4 #1
Handles like a 912 and goes like a 911
www.reSeeWorks.com
Old 11-30-2022, 04:15 PM
Jabate,
What's the difference between the peak corrected figures and the non-corrected figures?
Also is "ecm" the exhaust Lambda reading?
Thanks!
Old 12-01-2022, 01:50 PM
The second and third columns are not corrected numbers but are engine torque and horse power recorded on an engine dyno, not a chassis dyno.
Old 12-01-2022, 03:28 PM
The ecm is an exhaust Lamda reading, correct.
Old 12-01-2022, 03:29 PM
Corrected torque is corrected for atmospheric conditions on both torque and hp
The barometric standard is corrected for the conditions of the day.
Old 12-01-2022, 03:35 PM
Peter,
I mis read your question then realized what you were asking. The idea is to adjust the dyno results for the atmospheric conditions of the day using an SAE standard. So that the results are relevant for comparison to results obtained on days with different atmospheric conditions
Old 12-01-2022, 03:44 PM
I shared the dyno numbers and engine specs w/John D, cam grinder. His reaction. 100hp/liter. Cam kinda small. Could use a little more intake lobe. I like higher compression (engine already has) if looking to push peak hp up. So we can add more duration w/o killing mid range.
DC65/110 will be better from 5,000 on up w/little or no loss below
Old 12-02-2022, 04:00 PM
ADV-Performance's Avatar
Hi Jeff,
nice result congrats.
Ralph
Old 12-03-2022, 06:55 AM
It's a 914 ...
The lambda is a little richer than I'd expect (.77 is mid 11's AFR). Is that on purpose?
Old 12-03-2022, 12:31 PM
I will ask Paul Hasselgren of Hasselgren Engineering, Berkley, Ca, for an answer on the Lambda question. He tested and formatted the engine management system on his dyno. He should be in on Monday
Old 12-03-2022, 04:48 PM
Talked to Paul re ECU reading on print out.
Paul said 1. Intentionally ran richer to keep engine cooler at high rpm. 2. Print out is from Lamda sensor placed in muffler can and has slightly higher readings than the two Lamda sensors placed in right and left header pipe connected directly to Motec, which constantly adjust the AFR
Old 12-05-2022, 09:04 AM
2.5Polo 911 based engine
The crank w/rods; engine on way to dyno and a picture of the Rarly8/M&K 1 3/4’ long tube headers w/heat exchangers
Old 12-05-2022, 12:57 PM
It's a 914 ...
Nice lookin' motor
Old 12-05-2022, 01:53 PM
Who makes the case? Is it billet or cast? Great looking engine !
Old 12-05-2022, 04:13 PM
The case is cast and is made by Dean Polopolus
Old 12-05-2022, 06:09 PM
Under the radar
Trackrash's Avatar
This is the motor that Porsche should have made.
What is the bore and stroke? Is it using 3.6 heads?
Found this article. https://www.enginelabs.com/news/polopolus-engines-deconstructing-the-flat-six/#:~:text=The%20%E2%80%9CPolo%E2%80%9D%20motor%20as %20it%20has%20been%20dubbed,is%20a%204-cylinder%2C%20horizontally-opposed%2C%20overhead%20cam%2C%2016-valve%20engine.
Gordon
'71 911 Coupe 3,0L outlawed
Old 12-05-2022, 06:30 PM
Bore is 102mm. Stroke is:76.4mm
Heads are Xtreme Cylinder Head Castings, as sold for 964/993 with Xtreme Cylinder Head improved intake/exhaust port design
Old 12-05-2022, 06:38 PM
Pictures of the intake port and the exhaust port
Old 12-05-2022, 06:55 PM
