-   -   Case split shortcuts? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1130896-case-split-shortcuts.html)
The Watson 12-03-2022 11:37 AM
OK, let’s get the humiliating part out of the way. I left off the two sealing rings that should have been placed on the oil pump before joining the case halves. Didn’t realize until no oil pressure at initial startup. Insert favorite cuss word.
So, I have to go all the way back to opening the case. My question is basically what disassembly can I skip. Can I leave the left side cam tower, P&C’s intact. Or what other shortcuts might there be?
Appreciate any suggestions aside from “don’t be such a dumbass”!!
Flat6pac 12-03-2022 12:27 PM
My advice is don’t look for a shortcut, there is none…
Pull the heads, pull the P/Cs, through bolts, flange nuts
Split the case.
Now there are 3 ORing seals, two on the pump and one between the case halves.
Experience tells me to aviation permatex the two on the oil pump because I have knocked them off on putting the second half on. BTDT
sorry, good luck as experience teaches
Bruce
john walker's workshop 12-03-2022 02:54 PM
Remove the heads and cam towers as a unit, cams, rockers in place. O-ring seal under the pump, too.
doswald 12-06-2022 04:24 PM
It sucks, but we’ve all been there. Good luck resolving the issue.
DHO
Zuffenwerker 12-06-2022 08:08 PM
Keep the top end together don’t split the heads from the towers leave rockers installed. Don’t pull the pistons all the way from the cylinders leave the rings compressed.
The Watson 12-07-2022 05:26 PM
Thanks all. Turns out the seals WERE in place. It was a temporary plug blocking oil flow. Problem resolved and no need to split case. But good info from your replies nonetheless.
TibetanT 12-07-2022 06:44 PM
So Chuck, where was the "temporary plug" that was causing the issue?
Wondering if it was external to the case?
The Watson 12-07-2022 06:47 PM
It was just a shop rag that I had inserted into the tube. Somehow missed it.
brighton911 12-08-2022 06:47 AM
Lucky you. Same thing happened to a mate. He didn't see the oil light until too late and it was curtains for his engine.
