Driver's License Owner
Case split shortcuts?
OK, let’s get the humiliating part out of the way. I left off the two sealing rings that should have been placed on the oil pump before joining the case halves. Didn’t realize until no oil pressure at initial startup. Insert favorite cuss word.
So, I have to go all the way back to opening the case. My question is basically what disassembly can I skip. Can I leave the left side cam tower, P&C’s intact. Or what other shortcuts might there be? Appreciate any suggestions aside from “don’t be such a dumbass”!!
Thanks -- Chuck 1977 911S Backdate Street/Track, 1970 911T, '70 Triumph GT6+ Vintage Racer Project, '60 MGA Restomod/tribute, Cayman R, 1967 Moto Guzzi V700 |
My advice is don’t look for a shortcut, there is none…
Pull the heads, pull the P/Cs, through bolts, flange nuts Split the case. Now there are 3 ORing seals, two on the pump and one between the case halves. Experience tells me to aviation permatex the two on the oil pump because I have knocked them off on putting the second half on. BTDT sorry, good luck as experience teaches Bruce |
Remove the heads and cam towers as a unit, cams, rockers in place. O-ring seal under the pump, too.
It sucks, but we’ve all been there. Good luck resolving the issue.
DHO |
Keep the top end together don’t split the heads from the towers leave rockers installed. Don’t pull the pistons all the way from the cylinders leave the rings compressed.
it's not leaking....it's just marking it's territory |
Thanks all. Turns out the seals WERE in place. It was a temporary plug blocking oil flow. Problem resolved and no need to split case. But good info from your replies nonetheless.
Wondering if it was external to the case?
Ed Paquette 1983 911SC 1987 944S 1987 944 Manual (Donated to the Nat. Kidney Foundation) 1987 944 Automatic (Recently sold to another Pelican) |
It was just a shop rag that I had inserted into the tube. Somehow missed it.
Lucky you. Same thing happened to a mate. He didn't see the oil light until too late and it was curtains for his engine.
1986 Targa Guards Red 2021 MT09 SP |
