2.4L JE Piston orientation
Hi, starting assembly of my 73.5 CIS 2.4L T engine and need advice on my JE pistons orientation. The valve reliefs are cut offset from each other and different sizes. I think the larger cutout is the Intake side but want to be sure.
I am running a hotter cam as well and will conduct the clay assembly measurements as well as the timing and disasssmly again to assure proper valve clearance.
Old 12-06-2022, 02:12 PM
It's a 914 ...
stownsen914's Avatar
The standard for 911 pistons is larger relief is for the intake valve. So larger relief is the upper one.
Old 12-06-2022, 04:27 PM
you will notice a very sharp edge around the valve relief edge
make sure you round this off , give it a radius , no sharp edges ! they will make hot spots .
all sharp edges
Piston deck height @ 1mm , work like crazy to get this clearance
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 12-06-2022, 06:43 PM
