Two very specific questions regarding 2.4 engine install
Hey everybody,
I'm still working on my '73 2.4 restoration. I'm in the final steps before installing the engine. My first question is in regard to the harness routing to the starter and reverse switch. In the picture you can see the current situation. Why is there a gap in the engine tin and how is the harness supposed to be routed and fixed? My second question is about the gap between the plastic air guide / cover and the oil cooler. Is this normal? Thanks! |
First question: There's a rectangular rubber plug that goes on the harness. Ask Dennis (Timmy2) if he can get you one.
Second question: Here's a pic of how it should fit. Is that shroud aftermarket?
Thanks - that helps me a lot!
Do you or somebody else has the P/N for the rubber plug? I can't find it in the catalog. I'm located in Germany so I doubt Dennis will be able to help me. In regards to the second issue everything is original. Might be production tolerances on the oil cooler. I guess I will slot a piece of aluminum in between to get a proper fit. |
I found another pic with the shroud similar to yours. Might be "normal." To be honest, I've assembled quite a few of them and never paid much attention to the fit.
Try not, Do or Do not
The square harness insulator is correct and the gap between the air duct and the cooler extension will close as you tighten it. Both a pretty flexible.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Thanks again- also to Henry!
I‘m still looking for the part number of the rubber block. Help would be appreciated. |
PCA Member since 1988
I use a little silicone sealer around the edges of the oil cooler tin and air shroud, just to make sure all the cooling air goes where it's supposed to go.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Rubber block
Very good search rsscotty. I’ve purchased some O2 Sensor receptacles from Kroon. Not cheap but they have items other don’t. And coupled with shipping…small ouch…
