gasket set questions
88 carrera rebuild. Would you go for the wrightwood copper base gasket or try the reinz
new black coated gaskets? does anyone know if the reinz set comes the rsr seals?
tks for any help
Old 02-07-2023, 04:40 PM
Reinz set does not come with rsr seals.
it's not leaking....it's just marking it's territory
Old 02-07-2023, 07:16 PM
Thanks zuffenwerker.....
Old 02-08-2023, 08:49 AM
PCA Member since 1988
I swab a little bit of Permatex Ultra Black around the copper gaskets before I torque down the heads. Haven't had leaks yet.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 02-09-2023, 12:58 AM
Cevan's Avatar
I just got the Wrightwood Racing gasket set. It did come with the RSR seals.
It also came with a mystery red o-ring and this chrome covered plastic thing. Any idea what they are?
The o-ring is 20mm ID by 2.6mm and the plastic thing is 50 ID x 63mm OD.
1986 Carrera coupe - black on black
1972 CB500/4
Old 02-14-2023, 11:01 AM
The big one is probably for the early two piece crossover ear pipe
Bruce
Old 02-14-2023, 01:48 PM
red o-ring appears to be distributor. collar not like anything on my 3.2.
tks for the info on rsr seals.
Old 02-14-2023, 02:39 PM
The dist seal is thicker and is tapered
Bruce
Old 02-15-2023, 08:16 AM
Cevan's Avatar
Definitely not a dizzy sea. There was one included.
1972 CB500/4
Old 02-15-2023, 03:37 PM
