Where are the old threads?
There are supposed to be 16,534 threads in the this Engine Rebuilding Forum but only 48 threads + 3 sticky are visible.
At least 16,486 threads are missing. Where are they? Last edited by blue72s; 01-16-2023 at 06:49 PM.. |
They are there.....
Tony |
old threads
where do change to beginning?
From user cp, your control panel, settings & options, edit options, thread display options, default thread age cut off, show all threads.
Change here, bottom of forum page.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
It's a 914 ...
You can also search for older threads. The default list is just a view for browsing purposes.
gearhead
a trick I have learned is that the built in forum search function is a little wonky. So I will often go out to google, and search there, making sure I add the term “pelican” to my search.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
