Carmagic.us
Connecting Rods 3.2 vs 964
Good morning, I have a set of connecting rods that came from a 964, and want to use them in my 3.2 1984 engine.
I measured them and noticed that there is a difference in thickness at the big end. 1984 - 1985 = 21.70 - 21.80mm 1986 - 1989 = 21.85 - 21.90mm The 964 I got measure between 21.873 - 21.890mm which is within specs as for the 1986 - 89. All other dimensions are all withing specs. Why are the later con rods are thicker by 0.1mm ? and can they used as is with the 1984 crankshaft ? Thanks for any input on that. Engelbert
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems |
Check the center to center measurements as rods are for different strokes.
Carmagic.us
However, I found that the part number for the 3.2 1984 - 86 is 930 103 020 XX The Part number for the 3.2 87 - 89 and 964 3.6 is 964 103 020 XX XX for the weight group. So here again, it looks like the later con rods for 3.2 and 3.6 are 0.1mm thicker at the bid end, but why ? And can these used for a 1984 crankshaft. Thanks Engelbert
Carmagic.us
What I found is that the clearance rod/side wall is different for 78 - 85 and 86 - 89, source is Wayne's book.
78 - 85 is +0.200 - +0.350 86 - 89 is +0.100 - +0.200 That would mean the crankshaft is the same for all 3.2, but the clearance was reduced, and therefore the rod at the bearing end is 0.1mm thicker. So I can use them in my 84 Engine as is. Engelbert
PCA Member since 1988
Test assemble one on the crank. As long as it turns freely and has, say, 0.1mm of clearance, you should be good.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Carmagic.us
Thanks Engelbert
