88 carrerra teardown surprize
Disassmbling my 88 Carrera for vavle guides I think and found a nice little surprize
with fan shroud. I know it's magnesium and the crack is not through the shroud. No sign on inside. Can this be repaired or fixed by some method? Everthing is smooth and seems to work fine. Pic attached
It's a 914 ...
Contact mb911 here on the forum, he repairs fans and shrouds.
I'll bet if you look at the vanes connecting the outer ring to inner part, you will find more cracks.
1986 Targa Guards Red 2021 MT09 SP |
Try not, Do or Do not
Ben can weld them [most of the time] but those later Carrera ring are made of some pretty funky material. Even if you can weld it, you generally end up with a melted licorice weld.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
I recently had a machinist friend mill out a 901 housing to match the depth of a cracked carrera housing and he had to stop a couple of mm short of the total depth of 4.25" because the 901 hsg is a bit more tapered on the outside bottom of the alternator support center hub than the carrera hub, which has more meat there. Worked fine, No noticeable belt/pulley misalignment.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 02-07-2023 at 11:50 AM.. |
Henry and John: Tks for the info but I am new around here and don't know who Ben is.
Is that the same as mb911? tks |
The 9 Store
Yes. He’s an expert on welding steel, mag, alum, etc.
All used parts sold as is. |
I'll post video later this evening showing what John found when he pulled mine out. For sure had a similar crack as shown by OP as well as MANY other cracks all over the place. Looked like it had been in a wreck... Mine is certainly beyond the scope of repair. In a "budget-less" world, I'd have gone for that beautiful Rennline unit.
