Cost for Rebuilding
I’m ready for a rebuild. My 89 911 engine needs a refresh. Looking at rough estimates for doing a 3.4-3.6 from my current 3.2.
All in for a complete rebuild?
Old 02-04-2023, 07:12 PM
PCA Member since 1988
Read the parallel thread about “Separating Nikasil Piston
And Cylinder.”
How many miles on it? Why do you think it needs a refresh? Your labor, or you pay a Porsche engine shop to rebuild it? The price depends directly on how much you replace.
Old 02-04-2023, 09:08 PM
And Cylinder.”
I want a new engine and it would be a shop to do the work.
Old 02-04-2023, 10:00 PM
Sboxin's Avatar
How about $20-30K . . .
Some have done the 3.4L twin plug upgrade . . . I wouldn't try to do a 3.6L from a 3.2L case . . .
Best of luck on your project!
Regards,
Roy T
2002 Porsche Boxster S Cobalt Blue/Blk/Blk
Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car
Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine
Old 02-05-2023, 04:50 AM
These rebuilds add up extremely fast. There’s a lot of work that goes into making one of these right and look nice. Its not just take it apart replace parts and put it back together. It can be but generally speaking that’s not the best way to go. There’s a ton of labor in cleaning and machining. These engines are like an onion..layer upon layer. Each layer can have its unexpected costs.
To do a full rebuild really nice 20-30k is a little low but in the ballpark
it's not leaking....it's just marking it's territory
Old 02-05-2023, 06:21 AM
This is your chance to “build” your dream engine. Call and talk to William Knight (search on this site) and give him what you want your engine to do. He will design and engine just for you!
He will talk with you for as many hours needed to get you your custom engine.
I purchased all the parts from him ( trustworthy) and he gave me an engine builder close to me.
The process is long, trying to get all the right pieces together…some custom made, but it is well worth it.
Old 02-05-2023, 07:25 AM
I was thinking closer to 40-50k.
Old 02-05-2023, 09:17 AM
Engines this "old" need restoration more than rebuilding.
Old 02-05-2023, 09:27 AM
Yep
Old 02-05-2023, 11:04 AM
Yep
I’m not even sure I could get into a rebuild without budgeting 70k.
Old 02-05-2023, 11:08 AM
So tell…..
Old 02-05-2023, 11:48 AM
So tell…..
Not all engines are the same. Nor does every owner want the same result. Some don't see things wrong that other do.
What we have seen in the past is pretty typical. Apart for the normal replacement or reconditioning of the internal parts, much if not all of the exterior parts are worn out and need replacing or repair. Fiberglass shroud, wiring, throttle linkage, sheet metal, exhaust, the list goes on.
Call it what you want, it all comes down to what result you want. I tell customers, I can make money disappear quicker than David Copperfield in Vegas can.
Old 02-06-2023, 07:32 AM
...and of course, Neil's "X factor." Were you thinking Timex, or Rolex?
Old 02-06-2023, 07:53 AM
Perfectly explained!
If you give your word: keep it.
Old 02-06-2023, 08:48 AM
My ask is to rebuild what is needed to bring back life to a 3.2L that has either 118k or 218k
Miles on it. I’ve had it for 14 years w a broken odometer (the front number spins but has stopped at the 2 around 6 years ago).
QUOTE=Neil Harvey;11915636]Not all engines are the same. Nor does every owner want the same result. Some don't see things wrong that other do.
Call it what you want, it all comes down to what result you want. I tell customers, I can make money disappear quicker than David Copperfield in Vegas can.[/QUOTE]
Old 02-06-2023, 09:21 AM
Indeed. My "X" factor is the "Rolex" factor and I make no apologies about this. I want to provide a high end product for those that want this level.
Old 02-06-2023, 10:33 AM
70K?? I'll be happy to rebuild your next engine for that price!
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 02-06-2023, 07:18 PM
A few folks thought 50-60k were right. Others went with 20-30k.
Old 02-07-2023, 06:07 AM
If you would allow me to offer some advice?
Set your engine budget first. There is a limit to what you can afford. Once you have this figured out, this sets the parameters of what you can either achieve or maybe not start until you can.
The first part of the "build" is the heaviest in the labor. Disassembly, cleaning, crack checking and measuring will take up the major part of the labor. Typically DIY's and most shops will send out the parts for machining. The DIY and shop only do the assembly after the parts are returned.
Knowing that these early engines need a lot of attention, this is how we approach projects like this.
We quote the owner/shop an amount to disassemble, clean, crack check, and measure all parts.
Then we supply a second written quote to cover the machine work, parts, misc parts, any outside vendor work and the assembly/dyno. This way we know exactly what needs to be done and some concessions can be made then, in order to meet the budget. Maybe those upgrades cannot be afforded, making the engine look nice is not included, etc. The owner knows exactly what it will cost before anything is started. Both the disassembly cost and the "build" cost.
There have been times when the owner could not afford what was required and the project was stopped until they could. You don't get buried in a project that has no end in sight.
Often an estimate is given without any sort of knowledge of what is going on inside the engine. The engine is disassembled and then the telephone starts ringing, telling what horrors have been found. Now you are committed with a deposit given and that estimate has now grown in amount way more than ever expected.
I would hate that too.
Old 02-07-2023, 06:57 AM
Cairo94507's Avatar
Maybe contact Flat6pak (Bruce Abbott) on this site. He has been rebuilding 911 engines for decades. He rebuilt my '87 3.2 and it runs great.
'71 914-6 #0372
'17 Macan GTS
Old 02-07-2023, 07:49 AM
