So I am a little late to change direction on my build but figured I would open myself for some criticism. When I discussed this engine with Fred Apgar his response was "your going to run out of air at 160 mph". Fred was pushing me to increase the size of the intake ports.
My original intent with this build was to avoid opening up the intake ports, as this seems to mandate expensive mods to CIS or going with EFI to provide proper fuel at higher rpm.
So a more powerful stock engine using every upgraded bolt on engine part I could source within my small budget.
I didn't really consider that the SC cam may not be ideal for this goal until reading this thread.
1986 911 turbo
Been off the road for about 20 years now, 68,000 original miles, I am the second owner. I opened the engine due to wear of a few rockers and cam lobes. Plus the fear of the unknown inside the engine.
Heads refreshed with
New TRW sodium cooled valves
Eibach valve springs
Colsibro valve guides (from Chris Seven before his passing)
Intake and exhaust ports left stock diameter.
So heads are essentially stock
SC cams, freshened with pump drive added by Dougherty racing cams
Supertec rocker arms
Supertec head studs
964 turbo head gaskets modified to fit the 3.4 cylinders and the larger head studs
balanced rotating group
Supertec rebuilt oil pump with REM super finished gears
New standard main bearings
ARP rod bolts in stock rods with AA coated bearings
Mahle motorsports 3.4 liter pistons and cylinders
Rarly8 headers and exhaust
BB short neck intercooler.
Rebuilt 3LDZ turbo, with a slight trim on the turbine to reduce exhaust back pressure.
EngiNerding
Old 04-11-2023, 06:23 AM
PCA Member since 1988
David, you have a very different build from what was a discussed earlier in this thread. You are using boost, which changes pretty much everything.
In a supercharged or turbocharged engine, you do not want high overlap cams, because the boost will push the intake charge out the exhaust. Thus SC cams work well. If you want to change cams, then discuss it with a cam vendor tech representative. Really, the easiest thing for you to do is just crank up the boost. Consider installing an improved intercooler.
You should also start a thread on the sub forum for turbocharged engines.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 04-12-2023, 12:06 AM
From JD’s website.
SC on Turbo I/E 236/224 228/218 .450"/.395" 113 1.4-1.7mm
Most popular upgrade for street driven 930
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 04-12-2023, 01:47 PM
jpgroth's Avatar
I have a set of good condition SC cams out of ‘79 SC for sale if wanted
Josh
@joshgrowth
Old 04-12-2023, 05:54 PM
Jeff Alton's Avatar
We have a set of Turbo cams ground already to SC spec. Never installed.
Cheers
www.turn3autosport.com
Old 04-14-2023, 06:02 PM
Send a message via Skype™ to KNIGHTRACE
I was asked to help with some cam choices, looks like an old thread. Jeff Alton has some good cams for a turbo and reputable. M1 cam is best for CIS pistons with any induction but maybe a little big for turbo application. William
Old 07-30-2024, 11:46 AM
Constitutional Liberal
Turbo_pro's Avatar
"Best" is always an interesting claim. What makes the M1 cam the "best" when your only specification is the CIS piston dome?
Jim
“Rhetoric is no substitute for reality.”
― Thomas Sowell
Old 07-30-2024, 05:44 PM
