-   -   ARP Crankcase bolt confusion (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1136936-arp-crankcase-bolt-confusion.html)
Flat6pac 03-29-2023 05:56 AM
3 8mm on the oil pump?
Bruce
proffighter 03-29-2023 07:04 AM
Bruce
Thanks Bruce
Maybe, but I wont use there because oil pump needs 20mm (plus d2 = 16mm, overall 36mm). The left-overs are 22mm plus d2 = 38mm, too long. Only 2mm, but that's only thread length, there is the bull nose of about 8mm on top. Maybe there is not enough space on the other case half. However I will use them elsewhere or store them.
Gregvdb 01-13-2025 03:25 PM
Hi Roland,
Do you have the reference of the kit you bought? ARP website doesn’t specify years for 504-9501 kit and it seems that it’s for a “modern” 930, called them and they don’t know themselves what if fits
proffighter 01-30-2025 06:05 AM
Originally Posted by Gregvdb (Post 12390471)
Hi Roland,
Hello
No, only 504-9501 nothing more on the box and invoice. What I have found is this with parts list, but don't know its's 100% same that I received:
https://www.xn--schnellmann-rennsportzubehr-fzc.ch/technisches-zubehoer/arp-racing/weitere-arp-spezial-schrauben/arp-porsche-motorgehaeuse-schrauben/504-9501.html
