Diving in 911
964 build timing one bank only?
Any reason not to set up cam, rockers and timing on the left (1-3) bank prior to right (4-6) set up? Having exhaust stud fixed on #4 ( machine shop has the head) and thought I would finish building 1-3, unless there is something I am missing?
1976 911s Special Edition Turbo bodied IROC tribute
2002 911 Carrera C4S
1971 914 1.7 Tangerine
1989 964 Coupe/1992 964 Cab
1987 928s4 Granite Green / 1986 951
Old 04-14-2023, 10:01 PM
Any way you want to do it, you’re the builder.
Doing half the motor doesn’t make a lot of sense, at least do the complete top end.
C2 has a lot of leakage available and as long as you have it out attempt to handle the possible.
As far as cam timing, you have to match right and left
Bruce
Old 04-15-2023, 07:54 AM
Diving in 911
Thanks Bruce. It’s a complete rebuild. I’m just waiting on one of the heads back. Trying to determine if there is anything that should stop me completing the other bank. Most say to set the timing on #1 then #4. Looking to set 1-3 up then do 4-6 when I get the other head back and tower mounted.
Old 04-15-2023, 02:56 PM
Any way you like as long as the cam timing matches.
Bruce
Old 04-15-2023, 03:28 PM
