| Henry Schmidt |
06-05-2023 05:52 AM |
Originally Posted by gled49
(Post 12003195)
In post #5 what is the oil filter used with the 993 console?
After posting the answer to this question, I decided to do some serious investigating.
Although our original filters had some very impressive specifications, with some additional investigating and with some in-depth conversations about oil flow and particle retention, we were able to have Hubb supply us with a far superior filtration system. We are working closely with Hubb engineers to make a racing version of their filter available to the Porsche community.
Although these filters will be DYI serviceable, in the near future we hope to offer an in-house sonic cleaning service that will restore the filter to 99% of it's original flow specifications.
Hubb Filtration Systems
Filter Specifications
• Filter-in-a-filter design that is 99% efficient at removing oil contaminants at 25 microns
(versus 52% for conventional filters)
• Two pressure differential valves for increased oil flow and engine safety
• Filter is made of surgical stainless 316L weave and is cased with a hardened aluminum
shell.
• All internal parts are easy to clean and re-usable
• Entire filter is completely recyclable – no waste
• Filter can be drained 100% of oil – does not capture and hold oil in filter like paper filters
(approximately 5 ounces per filter)
• Improve oil flow by up to 5 times, when compared to conventional filters, to reduce
engine friction
• Produce an oil flow rate of up to 50 gallons/minute, compared to 10-12 gallons/minute
• Require only .2 PSI/gallon to push oil flow, compared to 7 PSI/gallon for conventional
filters
• Increase contaminant storage capacity by 5 times, but do not accumulate unrecyclable
oil like conventional filters
• Reduce carbon monoxide emissions by up to 30% and nitric oxide emissions by up to
16%
• Double your standard oil change interval reducing oil costs by 50% or more
• Ability to have Hubb clean the filters and manage your filter core inventory for you
http://forums.pelicanparts.com/uploa...1685969429.jpg
