-   -   1979 911SC 3.0 engine wiring question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1140586-1979-911sc-3-0-engine-wiring-question.html)
Len Chase 05-25-2023 06:01 PM
I am reinstalling my engine in my 1979 911 SC 3.0. I have (2) wires that I do not know were they go. They are part of the main wire harness from the engine. They both have a spade lug on them. One is yellow and the other is red with a black stripe. I have attached a few pictures of them. Any help would be greatly appreciated.
Thankshttp://forums.pelicanparts.com/uploa...1685062630.jpg
ahh911 05-25-2023 06:20 PM
Those look like thermo time switch (TTS) connectors (they control cold start valve on time duration in cis motors). It would be on the left chain cover, but I don't see one in your case. Not running CIS?
boyt911sc 05-25-2023 06:43 PM
WUR shown in Pic #1 & #3…….
That WUR looks heavily corroded. Wonder what the inside of the WUR may looks like.
Tony
PeteKz 05-25-2023 11:24 PM
Phil nailed it. Connectors to the TTS.
Henry Schmidt 05-26-2023 03:15 AM
http://forums.pelicanparts.com/uploa...1685096128.jpg
Len Chase 05-26-2023 11:45 AM
Thanks everyone for your input, it was a great help. Not sure how this got left out on the engine build. We did a hydraulic chain tensioner upgrade and the new chain cover had a bolt/plug in that spot. I WNET and looked though all of the old parts I replaced and found the old TTS in one of the boxes. I will order a new one and install it. Thanks again to everyone.
PeteKz 05-26-2023 12:10 PM
"I will order a new one and install it."
Wait until you see what the price of a new one is. :mad:
Reuse the old one, unless it's faulty.
boyt911sc 05-26-2023 02:08 PM
Len,
Your old TTS might still be good and working. Why don’t you test it first before buying a very expensive part ($250). I have a TTS tester and could do it for FREE. PM me if you are interested.
Tony
Len Chase 05-26-2023 06:34 PM
Originally Posted by boyt911sc (Post 12009280)
Len,
Tony
Tony,
Thanks for the offer. I am not sure how to PM in this forum. New to it and still learning.
Discseven 05-27-2023 03:49 AM
Originally Posted by Len Chase (Post 12009394)
Tony,
Len... click on Tony's name "boyt911sc" in the left column and a window will pop up. Click the "Send a private message to..." option. Then a private message screen will pop up. When Tony or anyone writes you back, you'll see a notification in the upper right of your screen under your "Welcome Len Chase..." box. Click "Private Messages" to get to your messages.
Alan L 05-27-2023 07:53 PM
The two lugs should be different sizes if they hook to the TTS. So you can't fit them wrong way round.
Alan
ahh911 05-29-2023 11:51 AM
If you don't like messing around too much, send Tony your WUR, AAR along with your tts. Maybe the other air valves as well. If you don't mind taking fuel pressure readings, verifying that your aar, etc.. are correct part numbers and working as you'd think they should, that's another story.
