1979 911SC 3.0 engine wiring question
I am reinstalling my engine in my 1979 911 SC 3.0. I have (2) wires that I do not know were they go. They are part of the main wire harness from the engine. They both have a spade lug on them. One is yellow and the other is red with a black stripe. I have attached a few pictures of them. Any help would be greatly appreciated.
Thanks ![]() ![]()
Those look like thermo time switch (TTS) connectors (they control cold start valve on time duration in cis motors). It would be on the left chain cover, but I don't see one in your case. Not running CIS?
81 SC. 930/16 (us model) |
WUR shown in Pic #1 & #3…….
That WUR looks heavily corroded. Wonder what the inside of the WUR may looks like. Tony |
PCA Member since 1988
Phil nailed it. Connectors to the TTS.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Try not, Do or Do not
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Thanks everyone for your input, it was a great help. Not sure how this got left out on the engine build. We did a hydraulic chain tensioner upgrade and the new chain cover had a bolt/plug in that spot. I WNET and looked though all of the old parts I replaced and found the old TTS in one of the boxes. I will order a new one and install it. Thanks again to everyone.
"I will order a new one and install it."
Wait until you see what the price of a new one is. ![]() Reuse the old one, unless it's faulty.
Len, Your old TTS might still be good and working. Why don’t you test it first before buying a very expensive part ($250). I have a TTS tester and could do it for FREE. PM me if you are interested. Tony |
Thanks for the offer. I am not sure how to PM in this forum. New to it and still learning. |
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
The two lugs should be different sizes if they hook to the TTS. So you can't fit them wrong way round.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
If you don't like messing around too much, send Tony your WUR, AAR along with your tts. Maybe the other air valves as well. If you don't mind taking fuel pressure readings, verifying that your aar, etc.. are correct part numbers and working as you'd think they should, that's another story.
