1978 Porsche 911 SC - Fuel Injection Lines
I want to upgrade my 1978 Porsche 911 SC - plastic fuel injection lines to the later style metal lines. Is there someone who makes these for the earlier year SC's that have the correct 8-mm banjo bolt fittings or come with the 8-mm /8-mm adaptors?
I read a post that Boxster GT had made these at one time.
PS. My first post so let me know if I need to supply more information.
Old 06-05-2023, 08:51 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Why make the lines when you can just buy good serviceable used lines and fittings?
I'm sure I can put together a nice set.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-05-2023, 09:29 AM
shoooo32's Avatar
I've replaced the ones on my '78 SC with a nice used set. I've also rebuilt a set using a polyamide fuel line fitting tool. It's not that hard - the line is inexpensive and the tool was $100 off Amazon.
-Tony
Instagram: @Pablo_the_Porsche | @RuchlosRallye
AchtungKraft #002
Old 06-05-2023, 09:49 AM
PCA Member since 1988
Why would you want to replace the plastic lines with hard inflexible metal lines? The metal ones are always in the way and hard to deal with when working around the engine. Either go plastic or braided SS like sandgroper linked.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 06-07-2023, 06:26 PM
