Ratings for case thru bolt O-rings
I'm planning to replace the blue o-rings I have from a Victor Rheims gasket set. The green Viton o-rings seem to be favored in most of the forum posts. The Pelican parts catalog shows 4 different o-rings and the green viton has the lowest rating.
green viton dph 3 star rating
red silicone Porsche 5 star rating
blue fluorosilicone Victor Rheims 4 star rating
red silicone OEM 4 star rating
What gives??? Does anyone know how the ratings are derived for the PP catalog?
Old 12-18-2023, 02:58 PM
This is a good question I assumed it was based off of customer reviews.
I have used the 3 popular o-rings (green viton, blue VR, and red from Porsche). I found the red Porsche ones to be a little too big so they can squish out easily. The blue ones also seem to squish out more often. I have not had a problem with the green so they are my go to.
I used the same lube on all and that has been my result
it's not leaking....it's just marking it's territory
Old 12-18-2023, 05:14 PM
Green with a bit of silicone paste.
206 637 4071
Old 12-18-2023, 05:27 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Not all "green" Viton is equal.
I get all my gaskets, seals and o-rings from Charlie @ Wrightwood Racing.
In some instances, I just trust the guys who are smarter than me. Charlie is flat out obsessive about getting the best he can find.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 12-18-2023, 05:47 PM
PCA Member since 1988
Listen to Henry. if Wrightwood sells it, it works.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 12-19-2023, 10:26 PM
