Help separating trans from 2.2
I have a fire damaged 2.2 that is seized, water from fireman in cylinders.
I want to separate the trans because it was fine but I can’t rotate the flywheel to insert bolts and spacers to release clutch bearing. Motor being seized and all.
Is there another way to do this?
Haynes manual says undo the clutch lever screw but no pics to guide me. It doesn’t seem obvious
Keep your stick on the ice!
69 911T
Old 07-12-2023, 04:19 PM
Navin Johnson
TimT's Avatar
Grab the clutch lever, pull it so it releases pressure on the t/o bearing, then spin the bearing to release.
'69 911 GT-5
'75 914 GT-3
and others
Old 07-12-2023, 04:32 PM
Worked like a charm, thanks timT
69 911T
Old 07-13-2023, 08:03 AM
