Hey! Nice Rack! "Celette"
Looking for a part source for CIS Injection Lines
I have a 73 2.7S with CIS. I am looking for a souce for the injector line tubing. I see there is complete lines with fitting available but I just want the line material.
Early Alien Sightings 914-M28/11 5.0 Hybrid (The Alien Sharkster) I think I smell your blood in the water WCC 04 done by the kids Who says Aliens only abduct people. |
Reach out to Len (BoxterGt)he can make any of the lines you require. Buy with confidence, he’s very knowledgeable and a stand up guy.
Len Cummings len.cummings@verizon.net Thanks, Saadi Sent from my iPhone using Tapatalk |
I second the reference to len. He knows what you need
Fuel Injection Lines……….
Rich, Unless you have experience fabricating fuel injection lines, I strongly recommend getting them from the professional builders. These are not like the rubber fuel lines you use in a carbureted system that has 5 psi. system pressure. A typical CIS like yours has 70~75 psi. system pressure and could get as high as 100 psi. when the fuel flow get restricted. Tony |
Thanks guys.
![]() Here is what I offer in case you want to buy complete assemblies.... ![]() ![]() len.cummings @ verizon.net
