Sleeve for leaking/grooved crank pulley snout Mezger engine.
I have a 01 Mezger engine with a grooved leaking pulley seal on the crank. I tried to change seals but it didn't work because of the groove I'm sure. What is the best sleeve to use? Any install advice? Thanks.
abit off center
Get a double lip seal so it rides on a different location
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Or see if you can find a Speedi-Sleeve that fits.
Yah I was thinking a Speedisleeve type solution would be be best.
