Engine Assembly
Is it possible to install all the rockers in the cam case, adjust the rocker screws all the way in, and then install on the heads? And not hold a valve open?
Tony |
so now you have to line up 6 rockers so they will be able to push the cam tower on?
I would not do it that way.
1976 911 1976 914 1986 951 |
Good Recollection……….
You can not install the cam tower onto the motor with rockers and shafts in place because you can not torque the nuts correctly. With rockers installed, how will you install the cam shaft? So the rockers and the cam shafts have to wait until the cam tower is installed and torqued correctly. The cam shaft goes first before the rockers. And I prefer to install the chain housing before the cam goes to the cam tower housing. You will find out why this way as you get to assemble your motor. Tony |
I do it different than most. Lay the heads in line, swab sealer on the cam tower, install on the three heads and torque the nuts, install cam, install rockers, turning the cam lobes away as needed, torque the shafts, turn cam keyway to 12 o'clock and install on engine which is in TDC position #1. Saves lots of time. Someone will surely say the the cam might be binding and you'll never know. Worked for me 40 years, YMMV.
Heads to Cam Case/Tower Rockers and Shafts in CC/T Head/Cam/Tower to Cylinder/Engine Case (Cam to 12 noon, crankshaft pulley to TDC) Chain Boxes to Case/Tower Chain guides, idlers, cam sprockets, tensioner's Time camshafts Rocker Covers Chain Case Covers |
This is done on the bench first, not on the engine yet. Install the assembly over the cylinders, Engine sideways on the engine stand. Flip it over and do the other side. Chain housings, sprockets, tensioners etc, cam timing, valve adjust, covers on.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 12-15-2023 at 09:08 PM.. |
I assemble basically as JW does but I turn down the crank from Z1 so pistons are inside the cylinders so there is no contact valves to pistons. Heads on, torqued, turn cams so keyway is up, then bring crank to Z1. Everything is lined up to install chain boxes, etc.
Bruce |
There really is no contact @Z1 as long as the keyways are @12 o'clock.
thanks guys!
