Reuse rockers w/ new cam?
Can I safely use old rockers with new cams? (Street engine)
TOT
Old 09-23-2023, 12:31 PM
Senior Member
No, they will need to be reground or you’ll risk destroying your cams.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 09-23-2023, 01:17 PM
Response
Dang that rabbit hole!
TOT
Old 09-23-2023, 02:51 PM
New rockers through our host are $124 a piece without tax and shipping thus gets a little expensive times 12. I took all my rockers to a machine shop for steel bushing inserts, total cost for bushings and machine work was well under $200. Additional rocker grinding and polishing would be $300 for everything although I didn’t ask for regrinding as my cams were fine and my plan was to reuse them.
Old 09-23-2023, 09:09 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Supertec rocker rebuild process:
We remove the old bushing and adjuster (if present)
Clean adjuster threads with 8x1.0 forming tap.
Black Oxide the rocker
Ream the bushing hole
Press in the new DP4 bushing and burnish
Surface the contact pad
Coat the contact pad with Moly dry film (TLML 2)
Bore oiling passage
Treat the rocker to a Cryogenic conversion process
On the shelf ready for exchange
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-24-2023, 08:28 AM
Rockers
Thanks ……clearly the answer.
TOT
Old 09-24-2023, 08:56 AM
Plus One on this.
Henry, what is the exchange price for a set?
Also, what is Moly TLML 2? Couldn’t find it on the website.
Bore oiling passage
Old 09-29-2023, 06:08 AM
Update
Old rockers shipped to Supertec today.
TOT
Old 09-29-2023, 06:40 PM
What was the price exchange or otherwise?
Old 09-30-2023, 06:24 AM
Does anyone know the cost of the ticket exchange with Henry? I would like a set.
Old 12-08-2023, 06:47 AM
Henry might know....
Old 12-08-2023, 07:49 AM
Clearly. But not in the website and no answer yet via email. I did think and try that first.
Old 12-08-2023, 09:43 AM
Henry is most responsive to phone calls. I'd just give the shop a call today.
Sent from my SM-G991U using Tapatalk
Old 12-08-2023, 09:58 AM
If you are going to put your services out there Id think a price would be helpful but what do i know.
1976 914
1986 951
Old 12-08-2023, 11:33 AM
Constitutional Liberal
Turbo_pro's Avatar
These thread live for ever and with prices changing almost daily, posting a price on a forum like this seems meaningless.
Call Supertec.
Jim
“Rhetoric is no substitute for reality.”
― Thomas Sowell
Old 12-11-2023, 08:52 AM
Prices
Agree….Henry is more than helpful and no muss no fuss. ……just call.
TOT
Old 12-11-2023, 01:32 PM
i know web cams rebuilds them as well for about 800$ a set
Old 12-14-2023, 09:42 AM
I paid $35 each exchange at EBS $420
Old 12-14-2023, 10:21 AM
