My Cylinder air guides don’t look right…
Every manual and book that I have shows a different arrangement than the guides that I pulled out of my engine.
I have a 1985 3.2 that appears to have never been taken apart before I started my tear down.
All of my guides have cut outs, including all 4 of the corner pieces.
The corner guides: one set of two is cut differently than the other set of two.
All of cut outs are punch cut with perfectly rounded inside corners, so I do not think that they have been modified by anyone.
Do I have two wrong air guides, or is this the right set up for my engine? If I do have the right guides, I am not sure which corners go where!
Any input appreciated.
Thanks, Dave
Here are just the four corners:
Dave
Project: 1985 Porsche 911 Carrera Coupe 3.2 to 3.4L "Carina"
PCA Member- Sacramento Valley region
Old 10-04-2025, 01:26 PM
That kind of looks like yours.
Old 10-04-2025, 03:09 PM
Hi
Think the link below will help you understand the factory air guide modification for 1964 to 1977 engines:
(Production equivalent embodied on later engines like yours.)
Cheers
https://www.klassikats.com/techincial-service-bulletin-center-air-guide-1964-77-911-930/
Old 10-04-2025, 03:18 PM
What you have is correct. The works drawing has the blades going showing both sides of motor.
The 1 inch cutout on the centers goes to the outside, the notched ends go against the case.
Bruce
Old 10-04-2025, 04:19 PM
Thanks guys- the Bentley manual and Wayne’s book must have been showing the older style. Everything I was looking at had one of the end guides with no cut-out.
Huge relief!
Dave
Old 10-04-2025, 06:37 PM
Yes, that is exactly what I’ve got. I need to get an ‘85 service manual…
Dave
Old 10-04-2025, 06:42 PM
You won’t ever forget the sequence now…
Bruce
Old 10-05-2025, 08:49 AM
Bruce
Got that right!
Dave
Old 10-05-2025, 12:54 PM
