clutch lever removal- absolutely necess?
85- 3.2l- watched all the vids- read wayne's version- but having a horrendous time trying to remove large clutch lever- the small lever was tough enough, but the main one is stuck, so that i dropped engine and trans with lever still intact- am wondering if i can remove transmission form engine so have better access to lever
advice? thanks
Old 01-07-2024, 08:13 AM
Try not, Do or Do not
Henry Schmidt's Avatar
advice? thanks
Once the small arm is removed the trans should separate from the engine. If the shaft is binding (rust or whatever) it may require a "little" force.
Year ago I had a shaft that just wouldn't turn, so we unbolted the pressure plate (9- 8mm bolts) by removing the starter and loosing the bolts through the starter hole.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-07-2024, 10:12 AM
Rust or whatever, it’s frozen on the vertical shaft and makes for adjusting impossible as well as the feel of the clutch, very hard.
Have used heat and air chisel with the point to remove the lever.
When reinstalling use axel grease or anti seize to lube the shaft because it needs to rotate freely to adjust the clutch properly.
Bruce
Old 01-08-2024, 05:56 AM
thx, guys- a couple of days of pb blaster, blows with hammer and finally success- will certainly install with grease- still have no clue as to why it was so important to remove!- transmission separated just fine and would have done so with arm in place- idk!!
Old 01-08-2024, 08:45 AM
If the shaft is frozen the fork won’t rotate out of release bearing grove.
Old 01-08-2024, 09:02 AM
