2.4 crank for a 2.2
I've read about putting the 2.4 crank in the 2.0 and I've read about putting the 2.2 pistons in a 2.4. Each for their unique advantages. But what about putting a 2.4 crank in a 2.2? Wouldn't that be about the same as putting the 2.2 pistons in a 2.4? Use the rods on the 2.4 crank as well, correct?
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
Thanks for the reply. Yes, that's what I meant, get a 2.4 crank and rods together to install in the 2.2. So, what CR do I end up with?
PRO Motorsports
The increased stroke length will give you a .55 point compression ratio increase over what it was as a 2.2 liter. But, since Porsche apparently overstates their compression ratios, it will work out to a number actually less than what the 2.2 claims to be.
Example: 2.2S is 9.8/1 CR. So, when these pistons are used with the 2.4 crank, it should work out to 10.35/1. But it doesn't. It measures out at 9.66/1. What this means is that the 2.2S isn't really 9.8/1, but something less to start with. This is from an excerpt from Bruce Andersen's 911 Performance handbook.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
In Wayne's Engine Rebuild - Top Engine Modification Picks (page 112), he also lists putting a 2.4/2.7 crank in a 2.2 case with E pistons & E cam with a CR of 10:1. He also confirms Tyron's figure above, that a 2.2S pistons and cams with a 2.4 results in a CR of 9.6:1.
J.C. Bear Original owner '71 911 Targa (32 yrs) It's not the critic who counts but the man in the arena - the doer of deeds. T. R. |
Author of "101 Projects"
This might be an error - I consulted with Bruce on this, and he mentioned (after the book was published) that he wasn't too sure. I think it should be about 10.3:1 or so...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
PRO Motorsports
Milt, what cams are you using? Those T pistons won't allow andything other than T cams unless you cut the valve pockets deeper, and even then, only E cams will clear since there isn't sufficient dome thickness to cut them any deeper than 1.8mm.
If you use the 2.2T pistons with the 70.4mm stroke, you'll end up with a little over 9:1 CR. 2.2T had 8.6:1 plus .55 for a net of 9.15:1
Wow! Interesting stuff. So, if the E cams get into the piston, how in the world did they get a high CR with S pistions and S cams?
BTW, I didn't buy the 2.2 motor I was looking at. So this whole thing might be moot. But, it's good to know these things. I'll get Wayne's 2nd book before I ask any more questions. I WILL BUILD A HOT ROD (someday). |
PRO Motorsports
Milt, the pistons match the cams. S pistons have relief pockets for S cams, so when you do this, you need to either get E or S pistons for E cams, and S pistons for S cams. Or machine the valve pockets if there is enough meat in the piston crown.
2.2S pistons will go right in a 2.4S motor because those pistons were designed to clear S cams already.
another clarification on this.
2.2T engine add 2.4 crank T cams 2.2 T pistons 2.2 rods will this work. I wanted to bump up my commpression usinf the 2.4 crank, but I hoped I would not need to replace the rods too.
I like them I drive them |
The 2.2 rods have different sized jounals than the 2.4 crank -> won't work.
You can use the 2.4 crank and rods with this setup, and it should work okay. I have a used set of rods for $150 ($25 each) if you're interested... -Wayne
I may do that wayne. i will call ya if I can't find some local.
