964 cam pitting - advice?
My 964 cams look reusable except for this pitting on the right camshafts cyl 4-6. What is the opinion here . Reusable / needs regrind?
Not reusable, and you’ll need new or regound rockers to go with the new/re ground cam.
Thanks!
I can’t help but notice the wear marks on your cam bearing surface, that may give an indication as to the general wear on your entire engine, it doesn’t look great to be honest. There’s been a lot of crap running around that engine and if it’s scored a hardened cam surface you can only imagine what lies within the crank bearings.
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo Workshop Coordinator at Ehrlich Motorwerks instagram.com/patrickossenkop ehrlichmotorwerks.com |
The 9 Store
If you can feel it with your fingernail, it’s not good.
All used parts sold as is. |
Yeah Im changing the crank too . full split |
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
check and clean the spraybar too.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
It's a 914 ...
Clean everything
