Life Cycles of Case Thru Bolts
Anyone have a feeling about the number of life cycles in a OEM Bolt at proper torque. I bet the factory had a guesstimate.
Old 11-22-2023, 07:41 PM
PCA Member since 1988
Many more than you will rebuild the engine!
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 11-22-2023, 10:09 PM
Very well, I guess Porsche’s Engineers said “der bolt is fine”.
Old 11-23-2023, 06:54 AM
Fleabit peanut monkey
Bob Kontak's Avatar
It's not a stretch bolt. It's fine. I would replace the o-rings if you have it apart.
1981 911SC Targa
Old 11-26-2023, 10:34 AM
