This my take on supporting the engine fuel wise, Radium and Fuelab.
Oh and another sidebar... Vintage race car carb tuning on my dyno, model A powered with an overhead valve conversion and twin Stromberg 97 carbs.
And Icarp stopped by with Kermit around that same time and we tuned his PMO carbs and 123 ignition. She definitely came out great. Looking forward to seeing him again, he is planning an east coast stop soon.
And back to the motor...
Standard Competition Motors, Berkeley Heights, NJ | Maxxecu engine management and Plex tuning calibration specialist and supplier | chassis dyno tuning and calibration consultations
http://www.instagram.com/standard_competition_motors
Old 09-08-2025, 08:41 AM
Made a mil spec connector firewall recess to help in future engine drops to disconnect the engine harness and map sensor hose.
Old 09-08-2025, 08:47 AM
Old 09-08-2025, 08:54 AM
Another side bar, had another visitor, a 2.7 MFI superstar. Runs great! And got a chance to try out two different mufflers in the name of science.
After getting the 72 dialed in I finally had a moment to put mine on the dyno and had a couple hours to dial in steady state tuning for drivability but I couldn't help myself to do a few wide open throttle pulls, It made decent power with a safe 19.5 degrees total timing and rich lambda target, within a those few pulls I was able to dial in the VE table to the rich target and at that point ran out of time.
The drivability and small throttle opening areas of the calibration really takes up all the tuning time and WOT is probably only 10% of the booked dyno time.
Old 09-08-2025, 09:05 AM
This past Thursday I had another small window of time and was able to do some knock sensor strategy programing and calibration. Just because your ecu has knock sensor capability does not mean it is a turn on and go endeavor. The strategy has to be tuned to your particular motor.
After some fuel angle tuning, gross ignition timing and finally some individual cylinder timing adjustments we ended up with this, a 25 hp increase from the week before with the placeholder WOT calibration.
A calculated 275 flywheel hp at 7168 rpm and 233 ftLbs at 4167 rpm. This number is calculated by Dyno Dynamics dynos and I have found it to be incredibly accurate if the dyno operator does their job properly.
This chart will show actual wheel hp.
All in all, that is where this particular air pump ended up. I have no doubts that it will benefit from some exhaust and intake tract length tuning and that will be my next step. I am curious what a different muffler situation will do for the engine and that will be my first stop.
At some point when I have achieved maximum efficiency in this configuration I will start my flow bench journey and see what happens then.
At the moment I will say, the sound this power plant makes at 8k rpm is AMAZING. Drivability with the DC60 power delivery is around stock like (with better response) up to about 4k rpm where it starts to feel lively, then after around 5k rpm it come on hard and then at 7k rpm it really gets happy (just like curve represents). Intake tone changes around 5k in a great way. Idle quality is good but requires more than basic tuning to get engine vacuum happy. Idle sounds great and is really stabile thanks to the Maxxecu controlling idle.
Old 09-08-2025, 09:15 AM
Such a nice build. Appreciate you updating us here. Wish you were closer in my backyard, as I have a new 3.2ss EFI project headed to a local NC tuner in a few weeks.
Thx, Patrick
912E-3.2ss
Old 09-08-2025, 09:46 AM
Thx, Patrick
Thanks Patrick! If you are ever in the NJ/NYC area stop by.
Old 09-08-2025, 10:18 AM
Everyone loves dyno videos right?
I am mid processing some video from the first dyno session and figured I'd share an unedited loaded 2k to 7.5k rpm pull with a controlled ramp up as opposed to a Dynojet pure inertia pull.
You can see me start to roll the drum with no load up to 4th gear, roll into the throttle until the brake holds the engine at 2k rpm while I transition to full throttle. When I get to full throttle it will hold the start RPM until I am out of acceleration enrichment and the motor stabilizes and will then allow the motor to rev to the pre determined 7.5k rpm at a controlled rate of climb.
On this pull I am about 5.5 degrees of total timing away from what eventually made best power and about 6% richer than best power as I snuck up to find out what the engine liked and what RPM it made best power at. As the calibration got to its best power output the exhaust note started to get crisper and happier.
Pardon the 20k cfm exhaust fan and 70 mph air speed cooling fan noise in the video, after a few RPM you can hear the motor start to sing over the fan noise. I am looking forward to trying different exhaust configurations for both power increase and tone.
Old 09-09-2025, 05:00 PM
swine's Avatar
Just tripping across your thread, you are THE MAN! Love seeing your feedback on MAXX, ive been keeping am eye out for others using their stuff. Seems like you are really spinning that motor up there! What cam and head work? Sub'ing to your thread, gold mine for those looking to go down the efi route referencing how you solved a variety of challenges/where you mounted things, etc.
Old 10-08-2025, 12:52 PM
Thank you swine.
I have the limiter at 8.2k and have the VE table stop at 8.5k so she spins pretty good!
Cams are DC60, and its completely stock port wise and valves but they are early big port SC heads. Wanted to start there as a base, when I get bored and have "exhausted" tuning I have plans to do a different top end situation.
I was too much in a hurry honestly to flow the stock heads on my flow bench during assembly but I do plan on flowing these when they get removed and then play with some changes.
Old 10-09-2025, 06:18 AM
swine's Avatar
Originally Posted by Rivet View Post
Thank you swine.
Cool! How does that trans like that on shifts?
Sent your a PM about the MAXX ecu solution, thanks.
Old 10-09-2025, 06:42 AM
Really like this thread. Thanks for following through and sharing the details.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 10-12-2025, 02:54 AM
