rod weight balance
I understand one must try to get the rod weights as close as possible. However, what if they are close, but when you weight the long rods and caps seperate then they are diffrent.
For example
1.-- long rod is 438 and the cap is 154 = total 592
2. -long rod is 425 and the cap is 164 = total 589
Total weight is close but each ends are far apart. long rod is 13 grams difference and cap is 10 grams difference.
I guess the rods are from diffrent engines..... unless that is normal?
Is that a major issue? It was running like that prior. Is it important to try to find a matched set? or no big deal just as long as the total weights are close.
thanks in advance
Old 12-20-2023, 07:12 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Our target number is .5 grams overall and end to end.
Any discrepancy greater than 9 grams at the start makes the set unusable.
Last year, I tried to get a set to .1 grams and spent 2.5 hours in a failed effort.
My guys got a pretty good laugh out of that.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 12-20-2023, 04:35 PM
For example
thanks in advance
You need to weigh each end of the the rods assembled. 9 grams is the limit. Any fixture like the one below will work.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 12-21-2023, 05:50 AM
oh.. so if i understand correctly. Even though the cap weights are way off from each other.. when connected and when i balance weigh them, i could still be in spec?
Old 12-21-2023, 07:28 AM
No. All of the big ends should match and all of the small ends should match.
You weigh the two separately because one is "rotating," the other is "reciprocating."
That is, if you want to do it correctly.
Old 12-21-2023, 08:02 AM
It's a 914 ...
stownsen914's Avatar
But don’t weigh the caps separately, that doesn’t mean anything by itself. It needs to be done as shown in the photo dpmulvan posted above.
Old 12-21-2023, 10:51 AM
Yes.
Old 12-22-2023, 05:45 AM
