964 3.6 plastic intake swap
I am dropping my 964 3.6 motor to reseal it. I have the older metal intakes, and I was wondering if there is any benefit other that weight saves to swapping to the plastic intakes? Thanks
Old 01-18-2024, 07:36 PM
Chain fence eating turbo
Yes, plastic ones supposedly flow evenly. The aluminum ones flow all over the place due to castings.
Old 01-19-2024, 06:45 PM
Plastic reportedly less heat sink too. FWIW
Old 01-21-2024, 07:22 AM
Thanks for the responses. Can I just purchase a used set of plastic intakes, and swap them for the metal ones? Plug and play?
Old 01-21-2024, 12:58 PM
You can also have the aluminum ones flow extruded to get them balanced.
The plastic manifolds used a different throttle body but from what I have read they are interchangeable.
Pete
Old 01-22-2024, 07:14 PM
Manual or Tip? There is an entire assembly on ebay for tip for $850 right now but it's for a tip.
I have just the plastic intake if you want that $200 shipped - but you will likely be chasing some other parts.
Old 01-24-2024, 04:38 AM
cheap!
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 01-24-2024, 10:40 AM
It’s for a manual.
Old 01-24-2024, 12:04 PM
