Looking at your lambda graph, I think you'll be fine. I'd be comfortable with this.
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Banned
I'm interested in exploring options for integrating an aftermarket ECU with a Varioram setup. What solutions or approaches are available?
Bump, anyone else have any thoughts?
81 SC 3.8 Conversion 2017 Macan S INSTAGRAM @tail_spinz |
Based on the data provided I would say the red line is borderline OK. The Blue line is too lean.
General guidelines 12.2 AFR - Safe Best Power at Wide Open Throttle (WOT) 13.3 AFR - Lean Best Torque. 14.6 AFR - Stoichimometirc Air/Fuel Ratio Value (Stoich) 15.5 AFR - Lean Cruise. 16.5 AFR - Usual Best Economy. I think you would want closer to 12.5 at wide open throttle. You might also want to try measuring your self with a wide band O2 sensor. Since the one a Dyno Pro is inserted in the tail pipe it is probably not as accurate as one screwed into the exhaust pipe. john |
I am running a dual wideband, one on each side and they match the dyno AFR.
