-   -   911 sc 3.6 to 3.8 engine rebuild thread (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1153713-911-sc-3-6-3-8-engine-rebuild-thread.html)
-Levi- 01-11-2024 07:25 PM
Hey everyone,
I wanted to share my 3.6-to-3.8 engine build.
The chassis is a 911 SC from 1981, I have been building the car over the past 15 years from bone stock and overall pretty tired to what it is today. The car is stripped down to the basics and the weight is around 2,250 LBS depending on the level of fuel (not including me of course.) Around 7-8 years ago I purchased a 1995 993 3.6 engine, added the VarioRaM intake manifold, S-car-Go 1'7/8 headers and a 997 GT3 exhaust to complete the engine conversion. During that time I put around 50K miles on the car.
Earlier this year the car started smoking consistently on every drive. After a teardown we discovered the expected valve guide wear and low compression in two cylinders. This prompted a rebuild, initially my plans were to just rebuild the engine in stock configuration, but a small savings on 3.8 P'Cs started me down that rabbit hole and my lack of self control kept it going.
Here is the car
http://forums.pelicanparts.com/uploa...1705029832.jpg
-Levi- 01-11-2024 07:26 PM
During this time I also wanted to rebuild and upgrade the factory transmission to better deal with the 3.8 power. i assumed I would break the 915 a year or two after I did the 3.6 conversion, but it never let go, I never had any issues, so it stays.
Engine Parts List.
The base engine is a 1995 993 engine with a varioram intake conversion from a later 993. Mahle 3.8 liter piston& cylinders @11.4:1 compression
993 RS Intake Valves
993 RS Exhaust Valves
Light Port and Polish
Pauter Lightweight Connecting Rods
AASCO Titanium Valve Springs
AASCO Titanium Retainers
AASCO Titanium Keepers
FVD Mechanical Rocker Arm Conversion
FVD Sport Cams for Mechanical Rocker Arms
Fabspeed Carrera Cup Intake
S-Car-GO 1 7/8 Headers
Gt3 muffler (top and bottom feed)
Arp hardware
Patrick Motorsports Light Flywheel
Patrick Motorsports 3.6 conversion Clutch
Rothsport Single Belt Pulley
Steve Wong Chip
It seems like horsepower figures are all over the place with other peoples builds, I assume crank will be somewhere between 300-325? Does anyone have any input?
http://forums.pelicanparts.com/uploa...1705029947.jpg
Transmission Parts list
1981 915 with LSD. At some point prior to my ownership the transmission had some significant damage and repair work as seen by the massive welds. I decided to keep the 915 case with the repairs as it has held so far and I like that it's part of the cars history.
Wevo Bearing Retainer
Wevo External Shifter
Wevo Solid Shift Joint
Wevo Reinforced Side Plate
RSR Spray Bar Kit
Wevo Internal Gate Shift Kit
Wevo Transmission Mounts
Wevo transmission pump
Setrab transmission cooler
Modified 964 Axles
http://forums.pelicanparts.com/uploa...1705029980.jpg
msmall215 01-12-2024 11:01 AM
Been following the action on IG, should be a riot when done. As far as expected power, I would actually expect a bit more than 300-325 crank.
I will preface this with it's not a 1:1, but just another data point is a 3.6 build I had in a previous car. 964 based 3.6, 11:5 CP pistons, DC21 cams (pretty mild), heads rebuilt to all stock specs (no port/polish, stock valve sizes), Jenvey ITBs/Motec, M&K 1 5/8 headers with heat and a 2 in/1 out powerhaus muffler...272hp/240tq at the wheels, so around 320hp crank with 15% drivetrain loss.
I think you'll do at least that and probably more, definitely in terms of torque with the Vram.
Mixed76 01-12-2024 12:45 PM
Please say more about the titanium valve springs? I've seen this described before but it always turns out to be just the retainers. Does aasco actually make valve springs out of titanium now?
Especially it seems galling between the spring, retainer, and keepers would be a concern?
Cool build, thorough and fit for purpose
Sent from my Pixel 7 using Tapatalk
-Levi- 01-12-2024 06:42 PM
Interesting, I’m going off what I heard from my builder so i may be mistaken. Looking online you may be correct.
Thanks Mike, appreciate the input as well. Big fan of your blue 911, spent more time looking at that than I should admit, lol. I would love to run. Motec, maybe in the future when I refill the bank accounts.
-Levi- 01-13-2024 08:28 AM
http://forums.pelicanparts.com/uploa...1705163268.jpg
-Levi- 01-13-2024 06:39 PM
Getting closer
http://forums.pelicanparts.com/uploa...1705199883.jpg
Bill Verburg 01-14-2024 11:04 AM
I know that you are using a 3.2 engine mount and crossbar w/ Sheridan f/g.
But am curious as to the possibility of using the Sheridan paces w/ a 3.6 mount and cross bar, any feelings on the subject?
Last year when I rebuilt my 993 in my '76 the engine was in and out a number of times, The main obstacle to raising the rear up was the 3.6 tin, I can see from your pics that the Sheridan f/g is ~1" lower than the 3.6 tin and if it can be used w/ the 3.6 aluminum console that might be the way for me to go.
Been looking for a 3.2 console for a few years now, from what I can gather(just a guess) Jeff Gamroth has been buying up all the spare 3.2 consoles.
Ryan_Cunningham 01-14-2024 02:04 PM
I just saw your IG post - Can't wait to keep up with this. Debating picking up a local '95 engine to swap into my 81SC.
-Levi- 01-14-2024 05:38 PM
Hey Bill!!
I wish I had more input for you. The engine mount came with the engine when I bought it years ago, at the time it bolted up so I didn’t give it much thought. I’m not a big fam of how my setup looks and I’m considering replacing it with something else.
Can I sent you an in depth video next time I’m around the engine so you can get a better view of it? Maybe some extra pictures?
-Levi- 01-14-2024 05:39 PM
Absolutely do it!!!
Let me know if you need any help along the way
-Levi- 01-14-2024 05:47 PM
Rebuilt and refreshed the Varioram intake manifold. Not the lightest setup, but I cant pass up the extra torque.
Refreshed hardware, all gaskets replaced and intake cleaned in and out.
http://forums.pelicanparts.com/uploa...1705282811.jpg
stanglife 01-14-2024 09:35 PM
Curious what options there might be for running an aftermarket ECU with varioram..
Bill Verburg 01-15-2024 09:12 AM
Originally Posted by -Levi- (Post 12171498)
Hey Bill!!
I'd be very interested in anything that you come up w/
here's mine, 993RS console/mount, 993 cross bar 993RS crank pully, modified 993 tin
http://forums.pelicanparts.com/uploa...1705337909.jpghttp://forums.pelicanparts.com/uploa...1705337949.jpg
very similar the setup I used when I had a 3.8RS vram in there
This setup provides a lot of room around the crank pulley for even the 3 sheave 993 pully and of course room to change belts., The 3.2 console you use has room for a single sheave pully, the older 3.0 consoles lack that room
The issue is that these 1" spacers are used to lower the rear of the engine for fitment, which in turn leads to exhaust fitment issues
http://forums.pelicanparts.com/uploa...1705338188.JPG
You can see here how high the 993 tin is compared to yours, I'm fairly certain that the cross bar height is the same or at worst very close to the odder 911 cross bar
http://forums.pelicanparts.com/uploa...1705338325.JPG
I'm thinking of buying the Sheridan f/g just to see how it fits w/ the 993 mount and cross bar
Bill Verburg 01-17-2024 08:02 AM
Spoke w/ Sheridan yesterday, The definitive answer is , No, his f/g won't work w/ the 993 console and crossbar.
-Levi- 01-27-2024 08:23 PM
Just a bit of progress this week, dropped the car off for additional body harness cleanup and got the intake manifold mounted.
Also, I got to drool over a real RSR and a SCRS at the shop. http://forums.pelicanparts.com/uploa...1706415237.jpg
-Levi- 01-27-2024 08:39 PM
And the engine
http://forums.pelicanparts.com/uploa...1706416351.jpg
stanglife 01-28-2024 05:41 PM
Lots of varioram excitement. ;)
Anyone used an aftermarket ECU for these? Is the variable runner length specific to RPM or does it also take into consideration throttle position or engine load? Just wondering how people are tuning for this. One of my wants for my build is DBW but I'd trade it for varioram intake, if I knew I'd be able to use an aftermarket ECU.
Bill Verburg 01-29-2024 08:46 AM
http://forums.pelicanparts.com/uploa...1361836217.jpg
A) Vibrating tube induction
If the gap (5) between sliding section (4) and central
intake distributor (6) is closed, the intake system is a
single-chamber vibrating tube induction system. Intake
air flows from the central intake distributor via vibrating
tubes designed for maximum torque to the cylinders.
B) Resonance induction
If the sliding sections (4) open, switching the system
from vibrating tube to resonance induction, the air flow
branches downstream from the air mass sensor (1).
One branch is connected to the central intake distributor
(6) of the single-chambersystem and one to the resonance
system (7) below the intake distributor.
From the central intake distributor, part of the intake air
flows through the intake pipe extensions, which act as
resonance tubes, directly to the intake funnels of the
short vibrating tubes and to the cylinders. The main intake
air stream flows via the second throttle flap and
the first large resonance tube of the resonance system
(7) to the resonance chambers. The resonance induction
system optimizes air flow to the short vibrating tubes.
C) Resonance induction with open tuning flap
The tuning flap (3) is installed in the second large resonance
tube. Initially, the tuning flap is closed. At a defined
enginespeed (5920 rpm), the tuning flap is opened,
increasing the flow area between the resonance chambers.
Air now flows to the resonance chambers via all
the connecting pipes.
Switch over conditions for intake pipe extensions
and tuning flap
1. When the ignition is switched on, the DME control
unit activates the solenoid valves. If the engine is
started, the intake pipe extensions and the tuning flap
are operated. When the engine has run up to idle
speed, the signal to the solenoid valves is deactivated
and the intake pipe extensions and tuning flap
are set to their basic positions.
2. If the engine speed reaches 5160 rpm and the
throttle valve is at least 50° open, the DME control
unit transmits an electrical signal to the solenoid
valves of the intake pipe extensions and the extensions
are operated, switching the intake system over
from vibrating tube to resonance induction.
3. If the engine speed is higher than 5920 rpm and the
throttle valve is more than 50° open, the DME control
unit opens the tuning flap, increasing the resonance
tube cross section.
yes, Motec and the like can be used to operate this
main vram benefit is midrange torque, for max hp use a GT3 intake
Bill Verburg 02-11-2024 10:32 AM
Any progress?
-Levi- 02-13-2024 08:28 PM
Originally Posted by Bill Verburg (Post 12191874)
Any progress?
Not much to update, waiting on some wiring harness pieces. My mechanic is going to install a connector in the main harness to separate the harness without disconnecting everything on the engine or body side of the car.
The body harness, wideband 02 sensors and the exhaust cutoff wiring has all been routed through the tunnel. http://forums.pelicanparts.com/uploa...1707884855.jpg
Bill Verburg 02-14-2024 10:51 AM
so the harness is in the tunnel?
usually that big hole in the bilk head to the right of the harness is where it would come through
can't wait to see it installed
I've started collecting the pieces to mount mine like that
got the 3.2 console
will use the Sheridan f/g tin replacements
debating whether to go for a Ti or SS cross bar, I like the Rennline version because of the boxed ends but Ti would be nice too
-Levi- 03-07-2024 07:55 PM
got the 3.2 console
Yep, the harness will still go there, just simplified and cleaned up.
I would like to do a different cross bar, I dislike the one I currently have, I just don’t really know wha5 will bolt on vs having to make something.
The Sheridan parts look even better in
Person, I highly recommend them.
I have no before pics, but the old harness was a hack job, chaotically finished in green electrical tape. This setup is so much cleaner with a main harness quick release.
http://forums.pelicanparts.com/uploa...1709869690.jpg
http://forums.pelicanparts.com/uploa...1709869990.jpg
-Levi- 03-31-2024 09:03 AM
Work has been hectic, but I was able to get a free day to start the install. Got a bunch of odds & ends finished up, and the engine is now mounted. I need a few more hours before we are ready to fire but we are getting close
http://forums.pelicanparts.com/uploa...1711900573.jpg
Bill Verburg 03-31-2024 04:21 PM
I'm going to pull mine this week to correct a few other issues and replace the tin w/ Sheridan f/g, also bought a Rennline cross bar & mounts
http://forums.pelicanparts.com/uploa...1711927133.JPG
Bill Verburg 04-03-2024 12:18 PM
Shorter studs are needed for the 3.2 console vs the 3.6 version
http://forums.pelicanparts.com/uploa...1712171775.JPG
Bill Verburg 04-05-2024 09:44 AM
Engine is back in the 99 3nvr fits like a glove
Heat needs to be re imagined though
http://forums.pelicanparts.com/uploa...1712335115.JPG
pocv0 04-05-2024 11:54 AM
Bill, where did you get that crank pulley ? I need one...
BTW- looks great.
Bill Verburg 04-05-2024 04:14 PM
BTW- looks great.
It is a 993 RS single sheave
part #s are
993-106-051-80 impeller hub for the alternator
993-102-050-40 pulley for the crankshaft
-Levi- 04-08-2024 10:31 PM
Got the car started over the weekend :)
Exhaust was on quiet mode and the fan needed adjustment in the first video.
https://youtube.com/shorts/0eUl2jDfAyM?si=BgfGs_K991Aupg8R
https://youtube.com/shorts/htasQ4l5LP8?feature=shared
bighead 04-09-2024 12:12 PM
I'm enjoying following your build, and you are inspiring me to do a 3.6 swap into my 911SC. I have found a US Spec 993 3.6 VRAM, but worried about the pain I've heard the OBD2 system causes. Any words of wisdom or recommendations on how you dealt with the OBD2 system? Thanks
Bill Verburg 04-09-2024 02:43 PM
Hey Bill!!
After looking at these things for the past 2 years , I Think that you are using the 993 console and crossbar
Sheridan told me emphatically that his f/g wouldn't work w/ that combo but you prove him mistaken
The f/g must allow the engine to sit higher than mine w/ the 3.6 tin did
after replacing the 3.6 console and cross bar w/ 3.2 version the engine sits where a 911 engine should, the rubber along the sides seals and more importantly the exhaust is tucked up where it should be
I'm pretty sure the these are the pieces you have
http://forums.pelicanparts.com/uploa...1712698606.jpg
these are the pieces I used
http://forums.pelicanparts.com/uploa...1712698677.JPG
down side is
1) I had to redo the heat, not an issue on yours
2) the stock air cleaner box just won't fit so I went back to the cone I used a few years ago.
-Levi- 04-10-2024 09:26 PM
That’s awesome!!! The 3.6 is a nice upgrade on the older cars.
I had the same concerns as you and decided to go with the 95 obd1 engine and retrofitted the VRam intake after the fact. I think the later cars can be done, but I didn’t want that extra challenge.
bighead 04-18-2024 12:08 PM
Who made your wiring harness? Mine is all hacked up, so I need a clean one like you have.
-Levi- 04-22-2024 08:17 AM
Same person that did my engine. That said, for the cost it's probably worth the extra cost to just have a mil-spec harness made.
bighead 04-22-2024 09:31 PM
Happen to know of anyone making mil spec harnesses for a 3.6 to SC swap?
-Levi- 04-23-2024 09:51 AM
Rasant and Ry-wire should be able to help.
-Levi- 12-20-2024 12:31 PM
Well, i finally made it through the break in miles and got to do a few pulls on the Dyno.
Here are the baseline pulls with a few things to note.
- I have a fuel cutoff from the SWchip at 6,200 RPM, I may be able to squeeze a bit more going up to the factory 6,800-7,000 redline
- it looks like my AFRs are a bit on the lean side and that will need to be adjusted for safety, maybe HP?
- I'm in Colorado at 5,280 ft elevation (i don't know if that really changes anything?)
- The last pull (in orange) was with the "quiet" mode selected on the GT3 muffler. I was expecting a bit more loss there.
i assume with some changes to the chip and AFRs i should be able to get a few spare ponies out of the car. at 268 Wheel Horsepower i assume I'm making around 310 crank, which puts me in the range of what i would say is reasonable.
Here is the build.
Mahle 3.8 liter piston and cylinder 11.4:1 compression
AASCO Titanium valve springs retainers
Steve Wong Chip
Arp hardware
Rothsport Single Belt pulley
Any thoughts or feedback?
DYNO VIDEO
https://youtu.be/ikdKA20s9oM?si=O4aztkx34I4ATpbL
http://forums.pelicanparts.com/uploa...1734726635.jpg
PeteKz 12-21-2024 01:14 AM
Since you are in Colorado, did the dyno operator correct for altitude? Typically a non-boosted engine loses about 3% HP per 1000ft, thus you would be down about 15% compared to sea level. If those were not corrected for altitude, then you have even more power at lower altitude than you measured.
winders 12-21-2024 04:00 AM
For the SAE correction, the Dynojet software corrects to 77 degrees F, 29.23 inhg and 0% humidity. At least they used to do that.
Also, I believe that dyno sheet is stating it is using SAE correction and that the correction factor used on the raw data is 1.19. So that 267.42 HP pull measured at 224.72 HP.
